    Add and remove items in cycle/combobox
    7 Posts 0 Posters 781 Views
      On 05/12/2004 at 05:09, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      has anybody a code sample or any hint, how to add and remove items to a cycle/combobox? I tried a lot, but can't get it working.
      P.S.: I created the combobox in GetDDescription().
      Thanks for any help.
      Torsten
        On 08/12/2004 at 01:22, xxxxxxxx wrote:
        Put them in the DESC_CYCLE subcontainer of the description.
          On 08/12/2004 at 01:50, xxxxxxxx wrote:
          Thank you Mikael.
          But i posted my question 2 weeks ago, tried everything, but can't get a solution. Maybe, i don't understand the usage of Subcontainers.
          I create my Combobox in GetDDescription
          BaseContainer unit = GetCustomDataTypeDefault(DTYPE_LONG);
          unit.SetString(DESC_NAME, "Active Object");
          unit.SetContainer(DESC_CYCLE, cycle);
          DescID descid(DescLevel(ACTIVEOBJECTINDEX, DTYPE_LONG, ID_OSCENE));
          if (!description->SetParameter(descid, unit, DescLevel(ID_OBJECTPROPERTIES)))
                  return false;
          1. i tried to save "unit" for later use as a member variable, but it doesn't work.
          2. I tried to access the BaseContainer of my combobox, but what's the id of the container (descid ???)
          Thanks for all replies.
          Torsten
            On 12/12/2004 at 09:19, xxxxxxxx wrote:
            I can access the combobox as Mikael said through DESC_CYCLE. But adding items doesn't work:
            void AddItems()
            {     AutoAlloc<Description> desc;
                 if (!desc)
                 {     return;
                 if(!((PluginObject* )this)->GetDescription(desc,0))
                 {     return;
                 const BaseContainer *descbase = desc->GetParameterI(DescLevel(ACTIVEOBJECTINDEX),NULL);
                 if(descbase )
                 {     BaseContainer *combobox = descbase ->GetContainerInstance(DESC_CYCLE);
                      if(combobox != NULL)
                      {     GePrint("Container found");
                           //Container OK, now add items
                           combobox->SetString(10,"Test1");
                           combobox->SetString(11,"Test2");
            What's wrong?
              On 12/12/2004 at 18:30, xxxxxxxx wrote:
              Howdy,
              Well, correct me if I'm wrong, but doesn't your code need to be inside MyPlugin::GetDDescription()?
              Adios,
              Cactus Dan
                On 12/12/2004 at 22:49, xxxxxxxx wrote:
                I create the combobox in GetDDescription, but have to add items to the combobox later, during execution of the plugin.
                Maybe, that the only way to manipulate the combobox is in GetDDescription. Is that so?
                Torsten
                  On 13/12/2004 at 08:11, xxxxxxxx wrote:
                  Howdy,
                  Yes, I believe GetDDescription() is constantly called so your descriptions would be getting rebuilt all the time.
                  Adios,
                  Cactus Dan
