    GeClipMap
    4 Posts 0 Posters 428 Views
      On 01/12/2004 at 03:07, xxxxxxxx wrote:
      Cinema 4D Version:   9
      Hello
      I want to create a customized tool for measuring the attributes of an object   like ( Functions->Measure and Construction ). Can I create the label in the editor window like "Perspective" which is at the upper left corner of the editor window or anywhere I like. I've been trying this using BaseDraw,BaseView,GeClipMap and EditorWindow creating ToolData Plugin.
      I can draw a rectangle on the editor window by using BaseDraw. But I cannot write out the text using GeClipMap.
      I want to know how to write out the text to the editor window.
      ZawMinTun
        On 05/12/2004 at 04:15, xxxxxxxx wrote:
        did you make sure you have called BeginDraw() before any drawing operation (also make sure to call EndDraw() afterward)?
        If not do so. 🙂
        Some code snippets would surely help identifying the problem.
        Katachi
          On 05/12/2004 at 04:23, xxxxxxxx wrote:
          Argh, sorry, GeClipMap is of course only for Bitmap manipulation (stupid me, but I just woke up an hour ago, so don´t blame me 😉
          I haven´t used the latest R9 for editor drawing operations, but I sort of heard that there are editor text drawing functions included, so this should work.
          I assume they are in the BaseDraw class just as all the others. But also here no guarantee as I am not at home and cannot check.
          HTH
            On 06/12/2004 at 20:45, xxxxxxxx wrote:
            Hello
            Thank you for your reply. I solved this problem in a not-so-good way. Like you say, it is possible through the BaseDraw class.
            With all my best wishes...
            ZawMinTun
