    ModelingCommandData in R9
    6 Posts 0 Posters 629 Views
      On 19/11/2004 at 12:20, xxxxxxxx wrote:
      Cinema 4D Version:   8.5+
      Howdy,
      I noticed that the ModelingCommandData in R9 has changed from what it was in R8.5:
      struct ModelingCommandData
      BaseDocument* doc;
      BaseObject* op;
      BaseContainer* bc;
      LONG mode;
      LONG flags;
      BaseObject* result1;
      void* result2;
      Now in R9 it is:
           ModelingCommandData() { doc=NULL; op=NULL; bc=NULL; mode=0; flags=0; result_ex=NULL; result=NULL; version=1; arr=NULL; }
           ~ModelingCommandData();
      BaseDocument*          doc;
           BaseObject*               op;
           BaseContainer*     bc;
           LONG                              mode;
           LONG                              flags;
      BaseObject*               result_ex; // don't use
           LONG                               version;
           AtomArray*      arr;
           AtomArray*      result;
      The R8.5 documentation says this:
      BaseObject* result1
      Resulting object for commands that create a new object. Not used if MODELINGCOMMANDFLAG_CREATEUNDO is set inflags.
      Note: You need to free this object yourself afterwards, or insert it into a document.
      void* result2
      Not used currently.
      In R8.5 if using MCOMMAND_CURRENTSTATETOOBJECT the mcd.result1 is the resulting object, but the R9 struct says "BaseObject* result_ex; // don't use " and the only other result is an AtomArray.
      So, I reckon my question is how do I use this in R9?
      Adios,
      Cactus Dan
      P.S. Any idea when the R9 SDK documentation will be released?
        On 19/11/2004 at 12:32, xxxxxxxx wrote:
        yes, this was necessary due to Multiselection I think. If the user selects several objects and you call this modeling command, result_ex couldn´t take it, so everything is now passed to the Atomarray.
        If you are sure there is only one object selected you could get the resulting object just like this:
        BaseObject* res = static_cast<BaseObject*>(result->GetIndex(0));
        //I assume result is used and not arr
        If there are several files, just loop through the indices. something like this:
        for(LONG i=0;i<result->GetCount();i++) {
        res = static_cast<BaseObject*>(result->GetIndex(i));
        //Do something with this object...
        Well, that´s how I would handle it 🙂
        And no, there were no announcements yet when the docs are ready.
        Katachi
          On 19/11/2004 at 13:03, xxxxxxxx wrote:
          Howdy,
          Ah, OK. There will only be one object from an object link in the tag, so I reckon the first example should work.
          Thanks, Samir.
          Adios,
          Cactus Dan
            On 19/11/2004 at 16:44, xxxxxxxx wrote:
            Howdy,
            OK, it works, but it's returning the object in it's "undeformed" state (probably because the deformation is on it's parent Null object). Is there a way to return just the object in it's deformed state without using MCOMMAND_CURRENTSTATETOOBJECT on it's parent?
            I looked in the SDK documentation and found this:
            Current state to object (returns object)
            Container ID                                                               Type            Description
            MDATA_CURRENTSTATETOOBJECT_INHERITANCE            Bool       Use inheritance.
            MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION          Bool       Keep animation.
            MCOMMAND_CURRENTSTATETOOBJECT has a container called MDATA_CURRENTSTATETOOBJECT_INHERITANCE but I don't understand what this is used for or exactly how to set it. I did a search here and in the archives but found nothing indicating it's usage.
            Adios,
            Cactus Dan
              On 15/06/2006 at 12:25, xxxxxxxx wrote:
              I'll like to know too how to set MDATA_CURRENTSTATETOOBJECT_INHERITANCE and MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION in 9.1 Sdk.
              ModelingCommandData cd;
                   cd.doc = op->GetDocument();
                   cd.op = geo;
                   if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, cd)) return FALSE;
                   AtomArray* result=cd.result;
                   BaseObject *Temp_Obj=NULL;
                   GePrint("Atoms Number:" + LongToString(result->GetCount() ) );
                   for (LONG k=0; TRUE; k++) {
                        Temp_Obj=(BaseObject* ) result->GetIndex(k);
                        if (Temp_Obj) GePrint("Index:" + LongToString(k) + " Name:" +Temp_Obj->GetName()); else return FALSE;
              i see a post where suggest to use
              cd.mode = MDATA_CURRENTSTATETOOBJECT_INHERITANCE | MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION;
              but if i start from null object that contain several objects, deformer.. GetCount return always 1.
              At last.. i need to know from a deformed object the Undeformed geometry and the deformed geometry. (vertex position)
              With CurrentStateToObject i always get the deformed geoemtry.
              Thanks in advance
              Renato T.
                     cd.arr = (AtomArray* ) geo;
                     BaseContainer bc;
                     cd.mode=MODIFY_ALL; //????
                     bc.SetBool(MDATA_CURRENTSTATETOOBJECT_INHERITANCE,TRUE);
                     bc.SetBool(MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION,TRUE);
                     cd.bc=&bc;
                          return FALSE;
                is not working.. always 1 element in array.
                What's i'm wrong?
                cheers
                Renato
