    Can't find Texture Tags using Hierarchy
    4 Posts 0 Posters 360 Views
      On 20/10/2004 at 03:39, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      Hi!
      I am using the Hierarchy Class to walk through the Scene Hierarchy. I am trying to Export an object that has a Texture Tag applied, but when I iterate through the Tags, there is no Texture Tag. UVW and Phong Tags as well as two hidden Tags (Tpoint & Tpolygon) are there, but no Texture Tag.
      Yes, the Material is applied to exactly the object I am looking at in the editor (it also shows up on that object when I call "Current State To Object" in the editor). Does the Hierarchy Class perhaps store Hierarchical Tags somewhere else?
      Timm
        On 22/10/2004 at 01:54, xxxxxxxx wrote:
        Confirmed. I'm investigating why this is and if there's a workaround. I guess one possibility is to use SendModelingCommand() with CSTO and do the hierarchy traversal yourself.
          On 22/10/2004 at 08:42, xxxxxxxx wrote:
          Hi Mikael!
          Thanks for the prompt reply. The problem is, that I need both, the original hierarchy and the hierarchy with the virtual objects at the same time and (more importantly) know in which relation they are standing (via, GetCacheParent()), so I can pick objects from both hiararchies. As far as I remember this doesn't work with SendModelingCommand, because the connections are gone, but I might be wrong here...
          Timm
            On 16/11/2008 at 22:35, xxxxxxxx wrote:
            An old thread, back from the dead...
                // helper method, since the main material won't have selections
                Bool hasSelection(BaseTag* tag)
                    if (!tag)
                        return FALSE;
                    GeData tempGeData;
                    if (!tag->GetParameter(DescID(DescLevel(TEXTURETAG_RESTRICTION)), tempGeData, 0))
                        return FALSE;
                    return tempGeData.GetString().Content();
                // the Hierarchy::Do method
                virtual Bool Do(void *data, BaseObject *op, const Matrix &mg, Bool controlobject)
                    ExampleStruct *d = (ExampleStruct* ) data;
                    LONG mode = op->GetRenderMode();
                    if (mode != MODE_UNDEF)
                        d->parent_state = mode;
                    if (controlobject) return TRUE;
                    if (op->GetType() != Opolygon) return TRUE;
                    TextureTag*   textag = 0;
                    BaseMaterial* material = 0;
                    BaseObject*   source = 0;
                    for (BaseObject* up = op; up && !textag && !material && !source;
                        (up->GetUp()) ? up = up->GetUp() : up = up->GetCacheParent())
                        for (BaseTag* bt = up->GetFirstTag(); bt; bt = bt->GetNext())
                            if (bt->GetType() == Ttexture && !hasSelection(bt))
                                TextureTag* tmp = static_cast<TextureTag*>(bt);
                                if (tmp->GetMaterial())
                                    textag   = tmp;
                                    material = tmp->GetMaterial();
                                    source   = up;
                    if (textag && material && source)
                        GePrint(String("Found material ") + material->GetName() +
                                String(" on TextureTag ") + textag->GetName() +
                                String(" on object ")   + source->GetName());
                    else
                        GePrint("No material was found for this object.");
