    SaveDocument in C++
    8 Posts 0 Posters 857 Views
      On 20/10/2004 at 00:13, xxxxxxxx wrote:
      Cinema 4D Version:   9.012
      Hi
      When I use following code in COFFEE, if its a new document, save as dialog box (windows default) will open automatically. Whats the relavent code in C++?
           var doc=GetActiveDocument(); // COFFEE
           var f = doc->GetFilename(); // COFFEE
           doc->Save(f); //COFFEE
        On 20/10/2004 at 01:08, xxxxxxxx wrote:
        I tried something like this...
            Filename fname;
            fname = doc->GetDocumentName();
            SaveDocument(doc,fname,FALSE,0);
        Is it the right way?
          On 21/10/2004 at 12:05, xxxxxxxx wrote:
          Hi there,
          it should be fine. Does SaveDocument() bring up a filename selector? If not and you want one, you should add
          fname.FileSelect(FSTYPE_SCENES, GE_SAVE);
          before SaveDocument.
          Timm
            On 21/10/2004 at 19:49, xxxxxxxx wrote:
            Even though I get the file selector window, "SaveDocument" returns FALSE. Here is my code for your reference
                 Filename fname;
                 if(SaveDocument(doc,fname,FASLE,0))
                   GePrint("TRUE - SUCCESS");
                 else
                   GePrint("FALSE - FAILED");
              On 22/10/2004 at 00:32, xxxxxxxx wrote:
              I guess "FASLE" is a typo, otherwise it wouldn't compile? (Please copy/paste code to avoid such typos.)
              This code seems to work:
                  Filename fname = doc->GetDocumentPath() + doc->GetDocumentName();
                  if(SaveDocument(doc,fname,FALSE, FORMAT_C4DEXPORT))
                  else
                On 22/10/2004 at 02:44, xxxxxxxx wrote:
                Mikael,
                It works fine, but it exports the currently opened new file (example untitled1.c4d) into the new file name which i specify thro' the file selector. I dont want to export, just want to save the current file. So that after saving I can see the new file (no more untiltled1.c4d) as the current active document.
                Please let me if you are not clear with my requirement. I am looking for the functionality of Save function under BaseDocument Object in COFFEE.
                  On 22/10/2004 at 02:56, xxxxxxxx wrote:
                  Ok, then I guess you could simply trigger the save menu command:
                      namespace c4d_symbols_coh
                      #undef IDC_OK
                      #undef IDC_CANCEL
                      #undef IDM_CM_CLOSEWINDOW
                      #undef HOTKEY_CAMERA_MOVE
                      #undef HOTKEY_CAMERA_SCALE
                      #undef HOTKEY_CAMERA_ROTATE
                      #undef HOTKEY_OBJECT_MOVE
                      #undef HOTKEY_OBJECT_SCALE
                      #undef HOTKEY_OBJECT_ROTATE
                      #include "../c4d_symbols.coh"
                      using namespace c4d_symbols_coh;
                      Bool MenuTest::Execute(BaseDocument *doc)
                        BaseContainer msg(COREMSG_CINEMA_EXECUTEEDITORCOMMAND);
                        msg.SetLong(COREMSG_CINEMA_EXECUTEEDITORCOMMAND, IDM_SPEICHERN);
                        Bool result = SendCoreMessage(COREMSG_CINEMA, msg, 0).GetLong();
                        return result;
                    On 22/10/2004 at 19:34, xxxxxxxx wrote:
                    Yes Mikael, it works now. You are great. Thanks.
