    DESC_REFUSE & DESC_ACCEPT?
    7 Posts 0 Posters 668 Views
      On 18/10/2004 at 19:07, xxxxxxxx wrote:
      Cinema 4D Version:   8.5+
      Howdy,
      When description link elements are created in GetDDescription, how do I use DESC_REFUSE and DESC_ACCEPT? The SDK doc says this about them:
      DESC_ACCEPT - BaseContainer - Contains the accepted IDs as strings. (E.g. GetString(5155) == "Obase".)
      DESC_REFUSE - BaseContainer - Contains the refused IDs as strings. (E.g. GetString(5155) == "Obase".)
      Should I be using SetContainer(LONG id, const BaseContainer& s)
      If so, how does it work? The second parameter is a BaseContainer but DESC_ACCEPT and DESC_REFUSE need to contain strings (E.g. GetString(5155) == "Obase".).
      Thanks in advance for any help.
      Adios,
      Cactus Dan
        On 21/10/2004 at 18:47, xxxxxxxx wrote:
        Howdy,
        Anyone? A clue to point me in the right direction?
        Adios,
        Cactus Dan
          On 22/10/2004 at 00:37, xxxxxxxx wrote:
          Yes, your guess was correct:
              descbc->GetContainerInstance(DESC_ACCEPT)->SetString(5155, "Obase"); // 5155 == Obase
            On 22/10/2004 at 06:53, xxxxxxxx wrote:
            Howdy,
            Thanks for the reply, Mikael. I'll give it a try.
            Adios,
            Cactus Dan
              On 22/10/2004 at 12:34, xxxxxxxx wrote:
              Howdy,
              Well, I'm doing something wrong, because now it's crashing Cinema.
              Here's what I tried:
              for (i=5; i<=linkCount; i++)
                   BaseContainer bc2 = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                   bc2.SetLong(DESC_CUSTOMGUI,CUSTOMGUI_LINKBOX);
                   bc2.SetString(DESC_NAME,"Target " + LongToString(i));
                   bc2.SetLong(DESC_ANIMATE,DESC_ANIMATE_ON);
                   if (!description->SetParameter(DescLevel(linkID,DTYPE_BASELISTLINK,0),bc2,DescLevel(ADD_CONTROLER))) return FALSE;
                   const BaseContainer *descBC = description->GetParameter(DescLevel(linkID),bc2,NULL);
                   descBC->GetContainerInstance(DESC_ACCEPT)->SetString(5102,"Obase");
                   descBC->GetContainerInstance(DESC_REFUSE)->SetString(5102,"Ospline");
                   linkID++;
              I don't think I understood the correct usage.
              Adios,
              Cactus Dan
                On 22/10/2004 at 15:51, xxxxxxxx wrote:
                Where is 'linkCount' coming from and being set? Using a member variable like that has caused me problems and headaches. I store counts in a LINK and extract to a regular member variable as needed to avoid them.
                Is it true that you want the same ID for both DESC_ACCEPT and DESC_REFUSE?
                Robert
                  On 22/10/2004 at 16:04, xxxxxxxx wrote:
                  Howdy,
                  The variable "linkCount" is stored in the tags BaseContainer and retrieved just before the loop with:
                  LONG linkCount = tag->GetData().GetLong(LINK_COUNT);
                  The value stored in the BaseContainer is updated when the Add and Subtract buttons are clicked.
                  Adios,
                  Cactus Dan
