    Adding object properties
    3 Posts 0 Posters 322 Views
      On 18/10/2004 at 15:21, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I am having trouble with my res file. I am trying to add properties to my plugin object, like the Oatam example:
      CONTAINER Oatom
           NAME Oatom;
           INCLUDE Obase;
           GROUP ID_OBJECTPROPERTIES
                REAL ATOMOBJECT_CRAD { UNIT METER; MIN 0.01; STEP 0.01; }
                REAL ATOMOBJECT_SRAD { UNIT METER; MIN 0.01; STEP 0.01; }
                LONG ATOMOBJECT_SUB     { MIN 3; MAX 1000; }
                BOOL ATOMOBJECT_SINGLE     { }
      my res file is as follows:
      CONTAINER CloneOmatic
           NAME CloneOmatic;
           INCLUDE CloneOmatic;
           String CLONEOMATIC_POINTS { }
           String CLONEOMATIC_MASTER { }
      When I run the plugin C4D crashes out to windows.
      Is there documentation on res file syntax?
      thanks
        On 18/10/2004 at 19:12, xxxxxxxx wrote:
        Well, yeah. The correct doc names for strings are:
        STRING (creates an EditText box)
        STATICTEXT (creates a StaticText)
        Case is IMPORTANT!
        Also, what's with the INCLUDE CloneOmatic? Include is for parent node types, not for the type being defined. For instance:
        NAME MyPluginObject;
        INCLUDE Obase;
        will include the Res description file for Obase. In your case, you may end up in an infinite loop including your Res file back into your Res file.
        Yes, do a search in the SDK documentation for "Description Resource" or go to the Contents for the same.
          On 19/10/2004 at 22:12, xxxxxxxx wrote:
          Thanks, that cleared it up for me. I didn't realize it was called a "Description" resource.
          Thanks again 🙂
