    Problems with MorphMixer and Bones
    3 Posts 0 Posters 354 Views
      On 15/10/2004 at 14:29, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      Instead of morph Objects, I'm storing the morph information in tags attached to the bones (just for organization - no direct effect on bones). But, the MorphMixer object is causing problems with the geometry as long as bones are fixed. Here's the general hierarchy:
      PolygonObject
      -- MorphMixer Object
      -- Bone MorphTag|MorphTag|...
      -----Bone MorphTag|MorphTag|...
      -----etc. on Bone Hierarchy
      Now, the morph sliders are working, the morphs are working, but the cause of the distortion on the overall geometry is hard to determine. Well, here's is the code for applying the morphs. If you see a problem needing attention or have an alternative methodology, please help!
      // Create morphed object
      BaseObject *MorphMixerObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
           Bool               dirty;
           LONG               index = MORPHMIXER_POSEOFFSET;
           Vector               *destadr = NULL;
           BaseObject          *ret = NULL, *orig;
           BaseContainer     *data = op->GetDataInstance();
           // Get Polygonal Object receiving morphs, return NULL if none
           if (!(orig = op->GetUp()) || !orig->IsInstanceOf(Opoint)) return NULL;
           // check cache for validity and check master object for changes
           dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA);
           orig->Touch();
           if (!dirty) return op->GetCache(hh);
           // Clone base object
           if (!(ret = (BaseObject* )orig->GetClone(COPY_NO_HIERARCHY|COPY_NO_ANIMATION|COPY_NO_BITS,NULL))) return NULL;
           // and transfer tags
           if (!op->CopyTagsTo(ret,NOTOK,NOTOK,FALSE,NULL))
                BaseObject::Free(ret);
                return NULL;
           // transfer name
           ret->SetName(op->GetName());
           // retrieve destination and base points
           destadr = ((PolygonObject* )ret)->GetPoint();
           ApplyMorph(GetActiveDocument(), op->GetNext(), orig, destadr, data, &index;);
           // send update message
           ret->Message(MSG_UPDATE);
           return ret;
      // Apply Morph to MorphMixer- recursive
      void MorphMixerObject::ApplyMorph(BaseDocument *doc, BaseObject *obj, BaseObject *mobj, Vector *dest, BaseContainer *bc, LONG *index)
           LONG               nr;
           Real               strength;
           LONG               *indices, *lind;
           Vector               *deltas;
           BaseContainer     *pbc;
           BaseObject          *mo;
           PluginTag          *pt;
           struct morphData mData;
           mData.bGet = TRUE;
           mData.indices = NULL;
           for (; obj; obj = obj->GetNext())
                // Apply related Morphs to MorphMixer list
                for (nr = 0; pt = (PluginTag* )obj->GetTag(ID_MORPHTAG, nr); nr++)
                     // Verify morph object
                     pbc = pt->GetDataInstance();
                     if ((mo = pbc->GetObjectLink(MORPHTAG_OPOLYGON_LINK, doc)) != mobj) continue;
                     // Get morph percentage from slider
                     strength = bc->GetReal(*index);
                     // Get morph point count, indices, and deltas
                     pt->Message(MSG_CHANGE, &mData;);
                     indices = mData.indices;
                     deltas = mData.morphs;
                     lind = indices+pbc->GetLong(MORPHTAG_MCOUNT_LONG);
                     // Add weighted morph
                     for (; indices != lind; indices++, deltas++)
                          dest[*indices] += (*deltas * strength);
                     (*index)++;
                ApplyMorph(doc, obj->GetDown(), mobj, dest, bc, index);
      Robert
        On 15/10/2004 at 17:22, xxxxxxxx wrote:
        Addendum:
        I find that if I move the MorphMixer object above the mesh object (the one being morphed) and change all of my references to boot, the distortion of the mesh object disappears (yay!), but now, as in another message, the bones do not respond (do not deform the mesh). If I disable the MorphMixer object, the bones work. If I enable it, they don't.
        What needs to be done to fix this?
        Robert
          On 16/10/2004 at 23:58, xxxxxxxx wrote:
          Anyone? Here's the updated code which seems to allow bones to work, but now the morphs 'snap' back as soon as the slider is released. Note that I'm fiddling with the GetClone() flags to see if something works.
               Bool               dirty;
               Vector               *destadr;
               BaseObject          *ret, *orig;
               if (!(orig = op->GetDown()) || !orig->IsInstanceOf(Opoint)) return NULL;
               //op->CheckCache(hh) ||
               dirty = op->IsDirty(DIRTY_DATA|DIRTY_MATRIX);
               op->Touch();
               if (!(ret = (BaseObject* )orig->GetClone(COPY_NO_HIERARCHY/*|COPY_NO_ANIMATION|COPY_NO_BITS*/,NULL))) return NULL; //throw ErrorException(ERROR_MEMORY, "MorphMixerObject.GetVirtualObjects.ret");
               if (!op->CopyTagsTo(ret,TRUE,FALSE,FALSE,NULL))
                    return NULL; //throw ErrorException(ERROR_MEMORY, "MorphMixerObject.GetVirtualObjects.CopyTagsTo()");
               // transfer name
               destadr = ToPoly(ret)->GetPoint();
               ApplyMorph(GetActiveDocument(), orig->GetDown(), orig, destadr, data, &index;);
               return ret;
          Robert
