    Edit Field info
    6 Posts 0 Posters 585 Views
      On 10/10/2004 at 15:07, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:      Mac OSX  ;
      On a previous post here, I was complaining about the impossibility of getting or setting the location of the cursor or the selected text. If I wan't to be able to set or get it, I must code my own implementation of a edit field, right? The problem is that I can't even set text colors (to simulate selections), in COFFEE.
      Would it be possible to code such a thing, in COFFEE? Is it a utopic task?
      Thank you in advance for any response.
      Rui Batista
        On 11/10/2004 at 03:59, xxxxxxxx wrote:
        I guess you are creating something from the GeUserArea class. In that case, you can (I think) choose the color with
        GeUserArea::DrawSetPen
        . But actually, I think that it is an endless task to code an editbox implementation in COFFEE. What do you want to code?
          On 12/10/2004 at 04:26, xxxxxxxx wrote:
          I need an edit field for entering code (a custom scripting language). So, I need a mini-text editor. I want to be able to search and replace it there and also know at what line and column my cursor is.
          Rui Batista
            On 12/10/2004 at 07:07, xxxxxxxx wrote:
            I wouldn't recommend coding a text editor, neither in C.O.F.F.E.E. nor in C++. The easiest way to get what you want would probably be to use C++ to load a platform dependent interface. (Note that "easiest" doesn't imply "easy".)
              On 12/10/2004 at 11:11, xxxxxxxx wrote:
              Actually, I would only need to have a way to get and set the selection inside a field. Its a shame that something as simple as that wasn't implemented either in COFFEE or C++ 😞
              Is there any way to run an external application from COFFEE?
              Rui Batista
                On 12/10/2004 at 15:09, xxxxxxxx wrote:
                I see that I can use
                [bool] GeExeuteProgram([Filename] program, [Filename] file);
                I will give it a try.
                Rui Batista
