    RenderDocument
    6 Posts 0 Posters 703 Views
      On 22/09/2004 at 07:47, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      No matter how I setup a bitmap or the RenderDocument flags it will not render an alpha to the bitmap ( the bitmap does have an alpha and does show up when I open the bitmap I rendered to and saved in PS ). This is an issue for us. Help!?
      Best Regards,
      darf
        On 24/09/2004 at 22:05, xxxxxxxx wrote:
        Could really benefit from a solution here. This is a production issue. RUnning out of time.
        Best Regards,
        darf
          On 25/09/2004 at 01:26, xxxxxxxx wrote:
          Sorry for the delay. I have already verified that
              Bool straight = FALSE;
              BaseContainer rdata = doc->GetActiveRenderData()->GetData();
              rdata.SetBool(RDATA_ALPHACHANNEL, TRUE);
              rdata.SetBool(RDATA_STRAIGHTALPHA, straight);
              AutoAlloc<BaseBitmap> bmp;
              bmp->Init(rdata.GetLong(RDATA_XRES), rdata.GetLong(RDATA_YRES));
              bmp->AddChannel(TRUE, straight);
              RenderDocument(doc, rdata, NULL, NULL, bmp, 0, NULL);
              ShowBitmap(bmp);
          doesn't seem to be enough to render an alpha channel. The question also arises if it's possible to render other multipass channels with RenderDocument(). I'll get back to you when I get a response from the developers.
            On 26/09/2004 at 00:08, xxxxxxxx wrote:
            Alphas and Multipass channels are automatically added by C4D, but also destroyed after the rendering is finished if no B3dBitmap was passed. Unfortunately the B3dBitmap (which is derived from BaseBitmap) cannot be accessed / created by the SDK yet. (For urgent needs and as a hack it should be possible to access the buffers in the Videopost though. Just inject your own custom Videopost and catch the buffers at the end.)
              On 26/09/2004 at 07:15, xxxxxxxx wrote:
              Erhmm...
              So I have caught the buffers. I don't understand what to do with them. Write them myself?   Sorry, just don't understand the idea.
              Best Regards,
              darf
                On 27/06/2006 at 03:06, xxxxxxxx wrote:
                The idea is to create a VideoPostData that uses for example Execute() at vp==VP_FRAME/open==FALSE, then look at vps->render->GetBuffer(VPBUFFER_xxx) to access the multipass buffers during the rendering. This is an example of doing this in vpcolorize.cpp (Execute() function) :
                    if (vps->vp == VP_FRAME && !vps->open)
                      VPBuffer* buf = vps->render->GetBuffer(VPBUFFER_RGBA, 0);
                      MultipassBitmap* mpb = reinterpret_cast<MultipassBitmap*>(buf);
                      MultipassBitmap* alpha = mpb->GetAlphaLayerNum(0);
                      alpha->Save(GeGetStartupPath() + "alpha.b3d", FILTER_B3D, NULL, 0);
