    Support reverse play function
    SDK Help
    0
    • H
      On 30/08/2004 at 05:31, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      Hi.
      I wrote a plugin with animatable parameter.
      Tag values of each frame would calculated from past values.
      Does support C4D reverse play function or i must write it itself? Any proposals?
      Thanks for answers.
      • H
        On 02/09/2004 at 02:02, xxxxxxxx wrote:
        There is a reverse playback function; just click the reversed play arrow. Or are you asking how your tag would find the previous values? I think the easiest way is to simply store the on that frame. When doing the final render C4D will roll through all frames, even if the rendering begins on a later frame.
