    GetContour & GetVirtualObject Issues?
    33 Posts 0 Posters 19.1k Views
      On 14/08/2004 at 08:53, xxxxxxxx wrote:
      Cinema 4D Version:   v9b
      Have the issues been resolved?
      GetContour is not called for frame redraws.
      GetContour does not work with Dependence Lists.
      GetContour should be rolled into GetVirtualObject and the SPLINE flag should simply return the object as an obejct type of SPLINE.
      GetContour and GetVirtualObject do not work with CheckDirty ( very helpful for simplifying flow ).
      GetVirtualObject and GetContour do not resolve dirty hierarchies correctly.
      These need to be fixed desperately.
      The GetContour issues are of serious importance.
      Thank you for your time.
      Regards,
      darf
        On 14/08/2004 at 09:06, xxxxxxxx wrote:
        An solution for this problem would be very very nice!
        GetVirtualObject sould be used for any object type, even Spline.
        There must be some solid Spline recognition method.
        Some of my Plugins create Spline and Polygon objects changeable.
        C4D Objects (Sweep NURBS) can recognize this Spline, but most of the other plugins can't.
        Regards,
        Remotion
          On 16/08/2004 at 13:27, xxxxxxxx wrote:
          It has only been an issue since v6.
          Happy, Happy.
          darf
            On 18/08/2004 at 00:54, xxxxxxxx wrote:
            I don't think there have been any additions in this area in R9. As with the rest of the application, most API changes have concerned modeling. So yes, GetContour() is still a second-class citizen compared to GetVirtualObject(), and the workaround has the same limitations as before.
            My pragmatical recommendation would still hold: use GetVirtualObject() for non-trivial spline generators and don't trust the OBJECT_SPLINE flag when determining what objects to accept as splines.
              On 18/08/2004 at 07:58, xxxxxxxx wrote:
              Most of the features in R9 mean very little to us. We were waiting to see if MAXON would fix the SDK issues that make C4D weak for serious motion graphics work. No offense Mikael, you are very helpful, but these SDK issues have become even more painful as C4D falls further behind in these areas. When S&T; doesn't support a set of splines created with the internal array object there is a big problem ( that was a clue ). More features, less functionality.
              Disclaimer: Mikael Sterner is very helpful person who has supported us through problems we could not solve by ourselves. We applaud that him for that.
              Regards,
              darf
                On 18/08/2004 at 10:29, xxxxxxxx wrote:
                Thanks for not shooting the messenger. Your points are noted.
                  On 03/05/2005 at 22:59, xxxxxxxx wrote:
                  this is a really bad news...
                  Now i understand why my new (trashed) plugin is not working .
                  cheers
                  Renato T.
                    On 09/06/2005 at 02:09, xxxxxxxx wrote:
                    simply as a little reminder for MAXON.
                    Not really what i would call helpful for Plugin developer.
                      On 18/08/2005 at 04:59, xxxxxxxx wrote:
                      News?
                        On 18/08/2005 at 14:05, xxxxxxxx wrote:
                        No, I'm not aware of any changes in this design.
                          On 18/08/2005 at 14:15, xxxxxxxx wrote:
                          Hello Mikael,
                          so.. i've done a plugin that construct a spline from different spline put like child.
                          This plugin only refresh the first time.
                          How i can get refresh when i change somethings inside it?
                          I really need of this plug because C4D will be powerful like houdini.
                          Renato T.
                            On 20/08/2005 at 01:39, xxxxxxxx wrote:
                            For 9.5 I've made a subtle change to help out with the whole spline from GetVirtualObjects issue.
                            A generator object can now output a spline that can be used by functions that look for a OBJECT_ISSPLINE. All you need to do is to supply the GetVirtualObjects and GetContour. In most cases the GetVirtualObjects is used, but for legacy some functions will still use the GetContour (why you also need to supply it and return your spline there too).
                            @Renato: your problem will be that GetContour handles the dirty check for you, this was never intended to be used for a generator input so does not detect dirty changes to other objects that you would normally do within GetVirtualObjects, you just need to force your object to become dirty (SetDirty()), you should be able to do this via adding an Execute into the pipleline before the generators priority, check if your object needs to be dirty and if it does set it to dirty and the cache will be cleared so GetContour is called.
                              On 20/08/2005 at 06:25, xxxxxxxx wrote:
                              Nice to know you guys wouldn't do anything for third party developers. Now that you decided to write a series generators / deformers / whatever you start fixing the issues that have been around for years. Congrats on being the same old Maxon you always were...
                              David Farmer
                                On 20/08/2005 at 08:59, xxxxxxxx wrote:
                                Actually FYI it was amended because it was on my API changes list (as many other things are too) and fitted in to be done for 9.5, it is not practical to just randomly change core areas (certainly something as sensitive as the caching system).
                                I help out here in my own time when I can because I too was once like the other positive developers here trying to work through the API and create something beneficial.
                                I am perfectly aware that you will never be happy unless you have 24/7 dedicate "must do this because darf says" support, I used to be on the developer support if you remember. As usual your attitude is no help to yourself or anyone else.
                                  On 23/08/2005 at 10:01, xxxxxxxx wrote:
                                  David:
                                  seem to work only if on Data... when i change the matrix alwais not working.
                                  But it's a good start 🙂
                                  Renato T.
                                    Very tactful.
                                    Demanding? David, seriously. Did you look at the dates? I posted here after more than a year on FC trying to get this fixed. The problems and complete ommisions presented in the ObjectData classes we horrible. No consistency. The fact you are working on it when we hear Maxon is desperately trying to build in JENNA like functionality in C4D is more than timing. Reminds of the functions I did not need for the volume tracer back in 2000 eh Philip? But Cebas needed them for PyroCluster so lets put them in! LOL... Gotta give you points for consistency.
                                    darf out
                                      On 01/09/2005 at 00:48, xxxxxxxx wrote:
                                      You're wrong actually, but whats new.
                                        On 02/09/2005 at 16:19, xxxxxxxx wrote:
                                        I make alot more money being wrong. 😉
                                        Funny thing is, I get along great with all of the other developers I have worked with. Apple is great, Alias is great, Adobe doing well. Huh, must be me.
                                        BTW: Tell Perry hi and we appreciated him outright fabricating his response to SLA support back in the day ( 3DWorld letter of the month where Maxon decided to lie and avoid supporting SLA for v6 which was contractually their responsibility ). That was a hoot! Fabrication of facts. Seems like a trademark for you guys. Time reveals all.
                                        Oh well, I said my peace. Time to stop wasting effort caring about something that has long since sailed.
                                        darf
                                          On 08/09/2005 at 16:40, xxxxxxxx wrote:
                                          David:
                                          i got my generator working with Execute... but i got a new problem.
                                          The plugin is generating a spline fine... but when i put it in a Hierarchy... is not refreshing anymore.
                                          plugin
                                          -- spline
                                          -- plugin <--- this is not refreshing
                                          why?
                                          Renato T.
                                            On 09/09/2005 at 01:35, xxxxxxxx wrote:
                                            Sorry, there isn't really enough information there to know what might be a problem. What do you mean by refreshing? Is this about the dirty update?
