    SetUniqueIP
    10 Posts 0 Posters 793 Views
      On 27/07/2004 at 13:40, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      What is the appropriate use of this?
      I assume that the IPs only need to be unqiue for the current hierarchy. I have a generator that takes inputs and generates multiple object hierarchies. In the simplest case I might generate with an input object such as:
      NULL
      Since these are based off particles I assume I would not set a unique IP for NULL and the other obejcts would go in order ( 1, 2, 3, 4, 5 ). If 4 was dropped then it would be ( 1, 2, 3, 5 ). Yes, I did set OBJECT_UNIQUEENUMERATION flag. I am actually having issues that it will freeze up ( loop ) when I go to redner out using anything that uses this infromation ( including the built in Vector Motion Blur ). A working example that uses multiple objects would be very helpful.
      Best Regards,
      darf - coreav
        On 30/07/2004 at 12:02, xxxxxxxx wrote:
        We need an answer to this question please.
        regards,
        David Farmer
          On 31/07/2004 at 04:13, xxxxxxxx wrote:
          Sorry for the delay, but I've been away for a few days. I'll try to think of a good example, but what would help me the most would be a small samples that crashes the VMB. (Reproducible crashes are always a good way to get developer attention... 🙂
          Also, is there anything wrong with your sample? Should that be 1...5 rather than 1...1? What is input and what is output? Sorry for the confusion...
            On 31/07/2004 at 08:41, xxxxxxxx wrote:
            The 1's are just object names. I explained in the paragraph how I was numbering them. I am just fishing for an SDK example that would use SetUniqueIP correctly.
            Best Regards,
            darf
              On 31/07/2004 at 16:37, xxxxxxxx wrote:
              Ok, so you have one input object ("1") that you create five copies of, some of which are only there some of the time? I'll see if I can reproduce the crash and/or create a working example.
                On 31/07/2004 at 17:10, xxxxxxxx wrote:
                Thank you.
                darf
                  On 03/08/2004 at 03:15, xxxxxxxx wrote:
                  SetUniqueIP()
                  I finally got around to trying the SetUniqueIP() thing. However, I couldn't find any problems with vector motion blur. This is the code I had:
                      BaseObject *AtomObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
                        BaseObject *orig = op->GetDown();
                        // return if no input object is available
                        if (!orig) return NULL;
                        // request polygonized input
                        hh->AddVFlags(VFLAG_POLYGONAL);
                        Bool dirty = TRUE;
                        // generate polygonalized clone of input object
                        BaseObject *main=NULL,*res=op->GetAndCheckHierarchyClone(hh,orig,HCLONE_ASPOLY,&dirty,FALSE,NULL);
                        // if !dirty object is already cached and doesn't need to be rebuilt
                        if (!dirty) return res;
                        if (!res)   return NULL;
                        // group all further objects with this null object
                        main = BaseObject::Alloc(Onull);
                        if (!main) goto Error;
                          LONG frame = hh->GetDocument()->GetTime().GetFrame(hh->GetDocument()->GetFps());
                          for (LONG i = 2; i <= 7; ++i)
                            if (!(frame % i)) continue;
                            BaseObject* cl = static_cast<BaseObject*>(res->GetClone(0,NULL));
                            cl->SetPos(Vector(i*100, 0, 0));
                            cl->SetUniqueIP(i);
                            cl->InsertUnder(main);
                          blDelete(res);
                        return main;
                      Error:
                        blDelete(res);
                        blDelete(main);
                        return NULL;
                  I've sent the scene I used to you by email. It animates just fine with VMB.
                    On 03/08/2004 at 03:17, xxxxxxxx wrote:
                    (Well, the scene mail bounced because of a full mailbox. It was just a modified atom object, with a cube inside, moving about with VMB turned on.)
                      On 03/08/2004 at 06:57, xxxxxxxx wrote:
                      I will work on it.
                      Thanks!
                      Regards,
                      darf
                        On 03/08/2004 at 15:05, xxxxxxxx wrote:
                        Ok, let me know how it goes. I also noted that it was instructive to remove the SetUniqueIP() line and the OBJECT_UNIQUEENUMERATION flag, just to see that the VMB didn't work without them (it detects erroneous diagonal movement when objects are removed).
