    Rotation XYZ
    SDK Help
    0
    • H
      On 21/07/2004 at 03:45, xxxxxxxx wrote:
      Cinema 4D Version:   6
      Platform:    Mac  ;
      Bonjour
      I want to drive the rotation of an object (a bone) by the rotation of an other object (a bone) but I want to controle the rotation on X Y and Z independently.
      I have write this :
      main(doc,op)
                var a = 1.00;
                var b = 1.00;
                var c = 1.00;
           var tg = doc->FindObject("Os bras G"); if(!tg) return;
      var mo = op->GetMg(); //position globale de l'os tagué
           var mt = tg->GetMg(); //position globale de l'os pilote
      var Roto = mt->GetHPB(); //rotation globale de l'os pilote
      var xo     = RotX( ); // compiler : variable or function expected
                       var yo     = RotY( );
                       var zo     = RotZ( );
      var pos = mo->GetV0();
           var scale = vector(vlen(mo->GetV1()),
                                   vlen(mo->GetV2()),
                                   vlen(mo->GetV3()));
      mo->SetRotX(xo * a);
           mo->SetRotY(yo * b);
           mo->SetRotZ(zo * c);
      mo->SetV0(pos);
           mo->SetV1(vnorm(mo->GetV1()) * scale.x);
           mo->SetV2(vnorm(mo->GetV2()) * scale.y);
           mo->SetV3(vnorm(mo->GetV3()) * scale.z);
      op->SetMg(mo);
           return;
      When I compile, on the line
                var xo     = RotX( );
      it display : variable or function expected. I don't understand what I have to do.
      Bests regards
      ( Sorry for my english, I am french)
      • H
        On 21/07/2004 at 05:10, xxxxxxxx wrote:
        I make mistake in my post. The right expression is :
        main(doc,op)
                  var a = 1.00;
                  var b = 1.00;
                  var c = 1.00;
        var xo     = RotoX( );   // compiler : varaible or function expected
                      var yo     = RotoY( );
                      var zo     = RotoZ( );
                                     vlen(mo->GetV2()),
                                     vlen(mo->GetV3()));
        mo->SetV0(pos);
        op->SetMg(mo);
             return;
        And my problem is on these lines :
              var xo     = RotoX( );
                      var yo     = RotoY( );
                      var zo     = RotoZ( );
        • H
          On 21/07/2004 at 18:21, xxxxxxxx wrote:
          Try this...
                           var xo     = Roto.x;
                           var yo     = Roto.y;
                           var zo     = Roto.z;
          • H
            On 22/07/2004 at 00:48, xxxxxxxx wrote:
            Thank you for your response.
            I try that before. No error of compilation and no error when I command "executate". But when I rotate the pilot bone around X axis the other bone turns around Z axis, when I rotate around Y axis the second bone turns only Z axis. In any way the second bone turns only around Z axis.
            Bests regards
            Damator
