    Vertex map access from a tag plugin?
    8 Posts 0 Posters 895 Views
      On 19/07/2004 at 23:44, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      is it possible to access and change a vertex map - from the same or another object - at the beginning of each frame from a tag plugin?
      I would like to sample lighting data to change the vertext map - any special considerations here?
      Thanks for any input!
      Kabe
        On 29/07/2004 at 06:41, xxxxxxxx wrote:
        Ok, maybe it's my Englich? Or was my question downright stupid? Have I overlooked something obvious?
        Thanks for any comment
        Kabe
          On 30/07/2004 at 17:15, xxxxxxxx wrote:
          Hi Kabe,
          if you register your tag plugin as an expression it will be evaluated for each frame. Then you can access the tag list of an object via
          BaseTag* BaseObject::GetFirstTag(void);
          You can check the tag type via
          BaseTag::GetType()
          The type ID for vertex map tags is "Tvertexmap".
          Then, when you cast the BaseTag object to VariableTag, you can access the actual vertex weights using
          LONG VariableTag::GetDataCount()
          LONG VariableTag::GetDataSize()
          void* VariableTag::GetDataAddress()
          In a vertex map there should be one Real value for each vertex (same order as vertices).
          Hope this helps. Cheers,
          Marcus
            On 03/08/2004 at 04:34, xxxxxxxx wrote:
            Thanks, it helps indeed!
            Kabe
              On 31/10/2004 at 09:44, xxxxxxxx wrote:
              how do i have to cast this ?
              please post example code
              thx
                On 31/10/2004 at 13:28, xxxxxxxx wrote:
                ok, i have all the weight data now, but how do i know which point belongs to which vertex ?
                http://wwws.htwk-leipzig.de/~ctheil1/code.jpg
                  On 31/10/2004 at 20:58, xxxxxxxx wrote:
                  void *GetDataAddress() should be cast to a Real* for vertex weight maps (Tvertexmap).
                  The array contains a Real element (weight value) for every vertex in the polygonal/point object - they are in the same order as you would get from object->GetPoint().
                  Since you are using COFFEE, some this may need conversion from C++ syntax. 🙂
                    On 01/11/2004 at 02:02, xxxxxxxx wrote:
                    thank you very much!
                    if they have the same order, it must be possible for me to get the relations. i hope so 🙂
                    by the way, i only could play around with this vertexmap stuff, because i found an example somewhere inside the i-net, but i currently don´t know how to make one by myself ... i didn´t found the tag in the list, but c4d works with it like i can see in the example.
                    so how do i have to create such a tag ? and how can i define the vertex to one special vertextag ?
                    greetz.
