    Need to _set_ POLYSELECTIONTAG_NAME
    6 Posts 0 Posters 518 Views
      On 13/07/2004 at 06:59, xxxxxxxx wrote:
      Cinema 4D Version:   7.303
      I'm currently writing an import plugin that successfully loads and creates a PolygonObject.  I'm currently running into two problems...
      1. when I add the PolygonObject to the document, it adds fine ( ie. doc->InsertObject(op,NULL,NULL); ) , but doesn't 'show up' until the user manipulates the interface.
      2. I'm creating some selection tags on the new PolygonObject and those are alo being created fine, but the names I'm giving them are not showing up.  Here's a code snippet of what I'm doing:
          typedef struct _objGroup
           String strGroupName;
           DWORD numFaces;
           DWORD currFace;
           DWORD *pFaceIndices;
          } objGroup;
          void ObjLoader::SetGroups(PolygonObject *op)
           objGroup *pGroup;
           SelectionTag *pSelect;
           BaseSelect *pbSelect;
           DWORD i, j;
           pGroup = &m_pGroups[0];
           for(i=0; i<m_numGroups; i++)
            pSelect = (SelectionTag * )op->MakeTag(Tpolyselection);
            pSelect->GetData().SetString(POLYSELECTIONTAG_NAME, pGroup->strGroupName);
            pFaceIndices = pGroup->pFaceIndices;
            pbSelect = pSelect->GetBaseSelect();
            for(j=0; j<pGroup->numFaces; j++)
             pbSelect->Select(*pFaceIndices);
             pFaceIndices++;
            pGroup++;
      ...as I mentioned, the selections are created correctly (they include the correct polygons), but the name field is blank.
      I'd appreciate any help with either problem.. thanks.
      - Keith
        On 13/07/2004 at 07:03, xxxxxxxx wrote:
        ...on the first problem, I should note that the importer is being implemented as a MENU plugin (it's an .obj file loader and creating it as a FILTER doesn't seem to work since C4D does that already).  I've also tried sending MSG_UPDATE messages to both the document and the PolygonObject.
          On 13/07/2004 at 07:32, xxxxxxxx wrote:
          Update:  I found the answer to my first question in another message here in the forum...  I added a GeEventAdd(MSG_DOCUMENTCHANGED); and the new mesh shows up fine now.
          Question #2 above is still open, however.
            On 13/07/2004 at 09:15, xxxxxxxx wrote:
            In a related note, things like:
                 TextureTag *pTexture;
                  pTexture = (TextureTag * )op->MakeTag(Ttexture);
                  pTexture->GetData().SetString(TEXTURETAG_RESTRICTION, pMat->strMatName);
                  pTexture->GetData().SetLong(TEXTURETAG_PROJECTION, P_UVW);
            ...don't work either.  I assume that I'm doing something fundamentally wrong with all of these.  The objects themselves are being created and added fine, but none of my SetString()/SetLong() calls on the BaseContainer (fetched via GetData()) are working.
            - Keith
              On 13/07/2004 at 13:33, xxxxxxxx wrote:
              Well, I found the answer (trial, error and inferrence).  You can't just do:
              ...you have to do:
                   BaseContainer bc;
                    bc = pTexture->GetData();
                    bc.SetString(TEXTURETAG_RESTRICTION, pMat->strMatName);
                    bc.SetLong(TEXTURETAG_PROJECTION, P_UVW);
                    pTexture->SetData(bc);
              ...the above code produces the desired results.
              - Keith
                On 13/07/2004 at 16:20, xxxxxxxx wrote:
                Or, try this:-
                BaseContainer *bc;
                bc = pTexture->GetDataInstance();
                bc->SetString(TEXTURETAG_RESTRICTION, pMat->strMatName);
                bc->SetLong(TEXTURETAG_PROJECTION, P_UVW);
                This is better as it saves the overhead of the BaseContainer being copied twice, and will be faster for the same reason.
                The documentation for 'getContainerInstance' says:
                'Note: Don't forget to send a Message() if you change any settings.'
                Cheers - Steve
