    Add separator in contextMenuColumn
    5 Posts 0 Posters 550 Views
      On 21/06/2004 at 00:37, xxxxxxxx wrote:
      Cinema 4D Version:   8.200
      I create my own context menu in the function CreateContextMenuColumn.
      And now, I like several separators in the context.
      I added this with the command:
      bc->SetString(FIRST_POPUP_ID, "Command1");
      bc->SetString(0,"");
      bc->SetString(FIRST_POPUP_ID+1, "Command2");
      The problem now, I see only the first separator. The other are invisible or not existing.
      Where´s the error??
        On 21/06/2004 at 09:10, xxxxxxxx wrote:
        Have you tried adding a submenu after the last separator to see if the separator then appears? Otherwise, your code follows the rules as mentioned in the SDK docs.
        Robert
          On 22/06/2004 at 01:46, xxxxxxxx wrote:
          Hi Robert,
          I didn´t try it to add submenu. Maybe it´s a workaround, but no real
          solution. But I will test it.
            On 22/06/2004 at 22:21, xxxxxxxx wrote:
            For these rare occasions, when more than one item with the same ID is needed, you can use bc->InsData(0, GeData("")) instead.
              On 22/07/2004 at 06:16, xxxxxxxx wrote:
              Hello Mikael,
              thanks, it works fine.
