    Real to INT = error....sometimes
    5 Posts 0 Posters 514 Views
      On 14/06/2004 at 21:44, xxxxxxxx wrote:
      Cinema 4D Version:   8.207
      Guess this:
      Vector pos;
      pos = pobj->GetPos();
      Ok....nice so far. I snapped the grid to 1.0, so I only get full coordinates, no float values.
      INT x = pos.x;
      Also sounds ok.
      Guess pos.x = 29.0000 ( this is what vc debug says ) Then, x = 29...in most cases, sometimes its 28!!!!!!!
      Any ideas?????????????????????
        On 14/06/2004 at 22:02, xxxxxxxx wrote:
        Hm, SAVELONG( ) seems to solve the problem.....but why is it a problem? I always wrote int = float without thinking about it....did I not understand something essential, or whats going on?
          On 17/06/2004 at 20:18, xxxxxxxx wrote:
          Floating point numbers only have finite precision. Since the INT conversion just scraps the decimals, it might happen that you lose 0.9999. Use something like "INT x = pos.x + 0.5" if you want to round to the closest integer.
          (Btw, please limit the number of consecutive punctuation marks to three, in order to reduce forum bandwidth use.)
            On 17/06/2004 at 23:08, xxxxxxxx wrote:
            Yes about the 0.9999 I did of course know, I just wondered because I set the initial objects position to 0/0/0, and move it with grid width 1.0, so decimal places should be all zero. Even if I debug it, they are zero, I thought the debug of vc shows the exact values of the variables, but not only an approximate value
              On 18/06/2004 at 00:55, xxxxxxxx wrote:
              you could also use Ceil() for example (or Floor() for the vice-versa result)
