    BaseContainer::SetLink with cloned object
    SDK Help
    0
    • H
      On 06/06/2004 at 08:51, xxxxxxxx wrote:
      Cinema 4D Version:   8.206
      Having a bit of trouble inserting an cloned object into a BaseContainer.
      Im doing a simple CurrentStateToObject command, and want to add the returned object into the BC.
             ModelingCommandData cd;
             cd.doc = GetActiveDocument();
             cd.op = op;
             if(!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT,cd)) return FALSE;
             BaseObject *oClone = (BaseObject* )cd.result1;
             BaseContainer *bctag = tag->GetDataInstance();
             bctag->SetLink(DUMMY, oClone);
             BaseObject *object = bctag->GetObjectLink(DUMMY,GetActiveDocument());
      As you can see, I directly read the link back again, but object variable is always NULL.
      What confuses me is
          bctag->SetLink(DUMMY,op)
      works. Both op and oClone are of type BaseObject* so I can't see why one works and the other don't
      • H
        On 06/06/2004 at 09:33, xxxxxxxx wrote:
        the returned object is not in the document that the tag is in I guess. Well, then it won´t work. At least that would be my spontaneous assumption.
        You cannot buy buns when there´s no baker or mall near you either! ;o)
        • H
          On 06/06/2004 at 09:34, xxxxxxxx wrote:
          Or: are you sure that the returned object is valid, so not NULL?
          • H
            On 06/06/2004 at 09:35, xxxxxxxx wrote:
            yea, everything not NULL. first thing I checked.
            • H
              On 06/06/2004 at 09:57, xxxxxxxx wrote:
              Ok, you was right 3D Designer.
              If I insert the clone object into the document then it works.
              but, I dont want to add the clone into the document.
              • H
                On 06/06/2004 at 10:04, xxxxxxxx wrote:
                But what reason do you have to link it then when it´s not in the document anyway?
                • H
                  On 07/06/2004 at 02:45, xxxxxxxx wrote:
                  The reason is purely for a quick shortcut.  I want a tag to hold information about a few objects in my scene. I want the tag to hold things like polygon array, object matrix, color properties, the GetName() of multiple objects.
                  But I dont want to hold information of the actual object, so I made a clone so I can modify the contents without distrupting the real objects in the scene.
                  I thought I would add the object into a basecontainer to save me the agony of creating a custom datatype to save the information I need.
                  It was just for a quick hack as I don't have experience creating custom data types and wanted to see results quickly.
                  But I should know that nothing is  as easy as you expect 🙂
                  So time to learn about custom data types
