    First simple plugin with problem
    7 Posts 0 Posters 824 Views
      On 27/05/2004 at 00:50, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      Hello to all !!
      Tnx for the yours advices, i have written this simple plugin to make a Cube primitive!! 🙂
      I notice that when i set the fillet on this Cube, it dosen't activate on cube !!
      Where i wrong?
      // Plugin ID
      const var PLUGIN_ID = 4444444;
      // Plugin class for creating objects
      class CreateCube extends MenuPlugin
      CreateCube(); // Constructor
      GetID(); // Get Plugin ID
      GetName(); // Get Plugin Name
      GetHelp(); // Get Plugin Caption
      Execute(doc); // Execute MenuPlugin
      CreateCube::CreateCube() { super(); }
      CreateCube::GetID() { return PLUGIN_ID; }
      CreateCube::GetName() { return "Create Cube Plugin"; }
      CreateCube::GetHelp() { return "Cube Primitive creation"; }
      CreateCube::Execute(doc)
      // Create cube
      var cube = new(CubeObject);
      var ct = cube- >GetContainer();
      ct- >SetData(PRIM_CUBE_LEN, vector(200, 100, 300));
      ct- >SetData(PRIM_CUBE_FILLET, 4);
      ct- >SetData(PRIM_CUBE_SUBF, 4);
      cube- >SetContainer(ct);
      // Insert a Cube object
      doc- >InsertObject(cube, NULL, NULL);
      __
      // Messages
      GeEventAdd(NEW_ACTIVE_OBJECT);
      doc- >Message(MSG_UPDATE);
      doc- >Message(DOCUMENT_CHANGED);
      __
      // Register MenuPlugin
      Register(CreateCube);
      Tnx in advance!!
        On 30/05/2004 at 17:25, xxxxxxxx wrote:
        Please use the CODE tags to preserve the formatting of the code better.
        In 8.5 it's best to use the values from the actual resource files, Ocube.h in this case: (You might have to copy these definitions, since not all parts of C.O.F.F.E.E. have been updated for 8.5.)
            enum
             PRIM_CUBE_LEN           = 1100, // VECTOR   - Side Length [>=0.0]
             PRIM_CUBE_SEP           = 1101, // BOOL    - Seperate Surfaces [only evaluated if no fillet is specified]
             PRIM_CUBE_SUBX          = 1102, // LONG     - X-Subdivision [>0]
             PRIM_CUBE_SUBY          = 1103, // LONG     - Y-Subdivision [>0]
             PRIM_CUBE_SUBZ          = 1104, // LONG     - Z-Subdivision [>0]
             PRIM_CUBE_FRAD          = 1105, // REAL     - Fillet Radius [>=0.0; <=len.x/2; <=len.y/2; <=len.z/2]
             PRIM_CUBE_SUBF          = 1106, // LONG     - Fillet Subdivision [>0]
             PRIM_CUBE_DOFILLET        = 1107 // BOOL     - Enable Fillet
        As you see, you have to set PRIM_CUBE_DOFILLET to TRUE to enable the fillet. And to be picky, the fillet radius should be a real number (4.0), not an integer (4).
          On 31/05/2004 at 00:32, xxxxxxxx wrote:
          Tnx for the answer Mikael ! 🙂
            On 31/05/2004 at 01:06, xxxxxxxx wrote:
            Now work, but i have seen that :
            ct->SetData(PRIM_CUBE_FRAD, 4.0);
            don't  work !!
            This work:
            ct->SetData(PRIM_CUBE_FILLET, 4.0);
            Where i found the correct settings?
            Tnx in advance for the answer!
              On 31/05/2004 at 09:24, xxxxxxxx wrote:
              Hi Mr. Braun,
              I think, what Mikael tried to say is, that you should use the ID values (e.g. 1105 instead of PRIM_CUBE_FRAD) directly, because the C.O.F.F.E.E. documentation isn't up-to-date and most IDs in the Cinema resources are not stored in C.O.F.F.E.E. constants.
              Marcus
                On 31/05/2004 at 16:33, xxxxxxxx wrote:
                The simplest way is to copy the whole enum-construct into the C.O.F.F.E.E. code. That solves the immediate problem, though you'll have to remove it in the event of the real constants being added to C.O.F.F.E.E. in future versions.
                  On 01/06/2004 at 00:36, xxxxxxxx wrote:
                  Tnx for the support !! :))
                  Tnx to all !! :))
