    Beginner question
    7 Posts 0 Posters 675 Views
      On 25/05/2004 at 01:49, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      Hello to all !! I'm new here !!
      I'm learning Coffee and i have just a beginner question: i want insert one primitive object by coffee language !
      How i make this ?
      Tnx in advance !! 🙂 _
      _
        On 25/05/2004 at 01:56, xxxxxxxx wrote:
        var cube = new(CubeObject); //Create a cube primitive
        if(!cube) return; //If the cube object wasn´t created then stop
        var doc = GetActiveDocuement(); //Get the active scene / document
        if(!doc) return;
        doc->InsertObject(cube,NULL,NULL); //Insert the cube into the scene
        GeEventAdd(NEW_ACTIVE_OBJECT);
        This should work. Download the COFFEE SDK for more information. It´s absolutely necessary to learn COFFEE. It´s here in the plugincafe.
        Have fun
          On 25/05/2004 at 02:01, xxxxxxxx wrote:
          Tnx for the answer Samir !! 🙂
          The COFFEE SDK that u refer is for 6.3 ?
          I have seen that more instructions isn't compatible with 8.5 ver. !
          Is right ?
            On 25/05/2004 at 07:22, xxxxxxxx wrote:
            yes that´s correct. Some are not compatible but most of them are still working fine.
              On 25/05/2004 at 08:10, xxxxxxxx wrote:
              Yep !!
              This from COFFEE sdk don't work into 8.5!!
              // Creates a cube that's 200x100x300
              var cube = new(PrimitiveObject);
              cube->SetPrimitiveType(PRIMITIVE_CUBE);
              var bc = cube->GetContainer();
              bc->SetData(PRIM_CUBE_LEN, vector(200, 100, 300));
              cube->SetContainer(bc);
              Where i found the correct instructions ?
              Tnx in advance for the answer !! 🙂
                On 25/05/2004 at 17:32, xxxxxxxx wrote:
                Please search the forum for "PrimitiveObject" and you'll find a list of threads dealing with this issue. (The example in the C.O.F.F.E.E. SDK is valid, iirc, in C4D R7 and earlier.)
                  On 25/05/2004 at 23:35, xxxxxxxx wrote:
                  Tnx Mikael !!
                  I have found more documentations !!
                  Tnx again!!
