    Shadowcasting in Volumeshader?
    5 Posts 0 Posters 383 Views
      On 24/05/2004 at 12:31, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I have a volume shader that does not have a surface calculation (means it does not work on geometry, but is used on an environment object). Now I need this volume to cast shadows though. What´s the usual way to do this? Any information or help is highly appreciated.
      Thank you in advance
      Samir
        On 25/05/2004 at 17:49, xxxxxxxx wrote:
        Wouldn't implementing CalcTransparency() and CalcAlpha() accomplish this?
          On 26/05/2004 at 09:01, xxxxxxxx wrote:
          thanks. I thought so too but it didn´t do so. Well, maybe I did something wrong. I will try again.
            On 26/05/2004 at 15:04, xxxxxxxx wrote:
            It works here perfectly, did you set the shader flags correctly?
            darf
              On 26/05/2004 at 16:55, xxxxxxxx wrote:
              Thanks for your answer. I do think so. Got SHADER_TRANSPARENCY|SHADER_ALPHA|SHADER_VOLUMETRIC|SHADER_RAYTRACING;
              All my calculations are done in InitRender and in CalcVolumetric. I am then passing transparency values to the according function. Is this the right way? I am pretty new to VolumeShaders and still feel a bit misplaced (though it´s getting better every day).
              But I just see that CalcAlpha is evaluated before CalcVolumetric. That´s probably the problem! Do I need to do my calculations in there too? That would surely slow down things. Hmm, I will need to further look at it.
              Thanks guys.
