    GePrint crash Cinema4D
    SDK Help
    0
    • H
      On 18/05/2004 at 07:14, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      Hi.
      If i have to this:
      GePrint (ptagMain->GetObject()->GetName());
      (ptagMain is valid pointer to a tag plugin!)
      then C4D crash always.
      What is wrong?
      • H
        On 18/05/2004 at 11:15, xxxxxxxx wrote:
        Did you check if ptagMain->GetObject() and ptagMain->GetObject()->GetName() are valid?
        • H
          On 18/05/2004 at 23:37, xxxxxxxx wrote:
          Hi.
          Thx for proposal. I forgot to check the pointer.
          Question:
          1. How can i check, that any one of my direct child objects has been moved in the hierarchy, new child added or old removed?
          2. How i can communicate between two plugins?
          • H
            On 19/05/2004 at 02:17, xxxxxxxx wrote:
            1. I have not done this but I think you can find this out by checking the Message function for your plugin type.
            For example TagData::Message() or maybe even CoreMessage
            2. What kind of communication are you after? I recently made a object data plugin that needs to retrieve data from a custom tag plugin. I simply had to get the BaseContainer of the tag object, and read the values from it
            Something on these lines
                BaseTag* tag = op->GetTag(MYPLUGINTAG_ID);
                if(tag)
                  BaseContainer bc = tag->GetData();
                  Real r = bc.GetReal(REAL_DATA,0.0);
