    String conversion to integer
    SDK Help
    0
    • H
      On 17/05/2004 at 05:41, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      I need to be able to convert a string to an integer.  It looked like int() might work but I get errors.  Is this the right function or is there another?
      Thanks.
      • H
        On 17/05/2004 at 06:18, xxxxxxxx wrote:
        StringToLong() will do it.
        • H
          On 17/05/2004 at 06:23, xxxxxxxx wrote:
          It might be eval() in C.O.F.F.E.E. if I remember correctly. (Though it does some additional evaluation, e.g. "5+5" will be 10. Whether that is good or bad depends on the context I guess.)
          • H
            On 17/05/2004 at 06:51, xxxxxxxx wrote:
            upps, haven´t noticed it was coffee. sorry. evaluate() will do so in COFFEE, but you need to cast it after the parsing for it returns a float value.
            • H
              On 17/05/2004 at 19:25, xxxxxxxx wrote:
              Thanks you guys.  That's what I needed.  I was looking for a StringToInt, Int, ctoi, or something of the sort.  I never read about evaluate.  That did the trick.
              Crew
