Tool mode ?
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 10/04/2004 at 04:31, xxxxxxxx wrote: User Information:
 Cinema 4D Version: 8.200
 Platform: Windows ;
 Hello! Is it possible to retrieve the mode that c4d is in? I would like to notify a plugin if the user has selected the rotate, translate or scale tool.Thanks
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 10/04/2004 at 05:05, xxxxxxxx wrote: BaseDocument::GetAction()
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 10/04/2004 at 05:57, xxxxxxxx wrote: Thanks, but is´nt that for the C++ SDK? I cant find any docs on it in the COFFEE SDK
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 10/04/2004 at 08:38, xxxxxxxx wrote: upps. Hmm, I don´t think it´s possible then. you cannot get General settings of the document in COFFEE so this workaround doesn´t work either.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 13/04/2004 at 15:38, xxxxxxxx wrote: Samir is right. This is currently not possible in C.O.F.F.E.E.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 28/10/2004 at 14:16, xxxxxxxx wrote: Howdy, OK, so how does GetAction() work in C++? The SDK says this: LONG GetAction(void) Get the current tool in the editor. Return
 LONGThe return values are the IDM_MOVE, IDM_SCALE etc. All these IDs are listed in c4d_symbols.coh in the resource folder of the main application. The IDs used need to be copied over manually. I tried this... LONG activeTool = doc->GetAction();
 if (activeTool == IDM_MOVE)
 GePrint("Move Tool active");
 }...but nothing happens. Then I tried this... LONG activeTool = doc->GetAction();
 GePrint("activeTool = "+LongToString(activeTool));...and it printed out this: activeTool = 200000088 In the c4d_symbols.coh file, it's listed: IDM_MOVE = 12356, When it said, "The IDs used need to be copied over manually" I thought it meant that I have to copy that line and paste it into my plugin's header file with the other enum's. I'm a bit confused. Can someone steer me in the right direction? Adios,
 Cactus Dan
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 02/11/2004 at 15:04, xxxxxxxx wrote: I guess that's because the former move tool was built into the CINEMA core and therefore had an IDM_* ID.
 In CINEMA R9, the move tool is implemented inside the Plugin Resource/modules/modeling, so the ID changed.The new ID is still part of the API, you can find it as ID_MODELING_MOVE in Resource/_api/ModelingIDs.h. Michael
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 02/11/2004 at 17:57, xxxxxxxx wrote: Howdy, Ah, that works. Thanks Michael. Adios,
 Cactus Dan
