    TreeViewFunction - Drag objects
    2 Posts 0 Posters 295 Views
      On 16/03/2004 at 04:48, xxxxxxxx wrote:
      Cinema 4D Version:   8.200
      i have create my own TreeViewFunction for a dialog. (like the SDK- ActiveObject  example). Now, I like used the drag functions within the tree. I overwriting the AcceptDragObject-Function and set the typ at INSERT_BEFORE|INSERT_AFTER|INSERT_UNDER.
      Now, I have got a funny behavior. I can´t INSERT_UNDER under the first entry. And if I try to INSERT_AFTER after the last entry, Cinema crashed with Stack Overflow. Can anyone help me,
      Marky
        On 17/09/2007 at 22:03, xxxxxxxx wrote:
        I realize that this is an extremely old topic, but I must concur with this even for R9 and R10. I am experiencing similar odd behavior with AcceptDragObject() when drag-n-dropping an element to a new position within the list - no crashing, just an unexpected pruning of my root tree list. The behavior is pretty much random - I can drag-n-drop on one try and *poof* there it is or I can do the same dozens of times before it happens. I've double-triple-quadruple-quintuple-... checked MY code and it is about as solid as any code out there: the logic is perfectly perfect. Thus I am led to believe that this is some buggy behavior in the TreeView itself. I cannot provide any situation where this is bound to occur - it just happens and I'm left with a portion of the list items gone for good.
        Pray-tell what could be the cause? Is there any message or clue beyond just this method to provide an informational check here?
