    Filename from GUI
    5 Posts 0 Posters 572 Views
      On 08/03/2004 at 07:24, xxxxxxxx wrote:
      Cinema 4D Version:   8.207
      I created a dialog using the ResEdit Plugin (V 1.7). This dialog's resource file includes a FileSelector field:
      FILENAME FILSELECTOR_ID
      After selecting a file using this GUI there's a value shown in the edit-field but I cant't get the shown Filename for further usage.
      I tried this code to get the Filename but using this code had no success:
      Filename     file
      GetFilename(FILSELECTOR_ID, file); //from GeDialog
      Why I don't get the Filename from the field? Is there any other way?
        On 10/03/2004 at 02:09, xxxxxxxx wrote:
        No, that is the way it's supposed to work. What does the function return? (And is anything put at all into the "file" variable?)
          On 10/03/2004 at 02:29, xxxxxxxx wrote:
          The function returns TRUE but the 'file' variable contains nothing.
          I checked it with file.Content() but it always returns FALSE.
          For now I did a workaround:
          I'm using an edit-field and a button instead of the FileSelector field. That's not fine but it works.
          But if you have any idea what's going wrong, please let me know.
            On 17/03/2005 at 08:30, xxxxxxxx wrote:
            Having this same issue. Too bad it was never resolved. Does that mean it was a bug?
            David Farmer
              On 17/03/2005 at 09:43, xxxxxxxx wrote:
              I doubt it works. The docs for GetFilename say:
              Retrieves the text from string controls as a filename.
              This is not support for filename customguis!
              Get the customgui with FindCustomGui and retrieve the filename like this:
              path = fngui- >GetData().GetValue().GetFilename();
              Hope that helps.
              Katachi
