    How to know inside a shader what exact object is the shader attached.
    c++
    3 Posts 1 Posters 1.0k Views
    • R Offline
      rui_mac
      I created a shader that needs to know exactly what object it is attached to.
      So, if a material that contains that shader in, for example, the Color channel, is assigned to different objects, it will produce different results.
      I know that the VolumeData contains a list of all objects being rendered and that each object in the VolumeData, obtained by GetObj(i) contains a RayObject that contains the texture_link parameter.
      But, inside my shader, I get ALL the objects that include the material that contains the shader.
      So, from inside the shader, how can I know what is the exact object that is being rendered?
      • R Offline
        rui_mac
        I guess I can only make sure I know what is the object being rendered from inside the Output method, as in the InitRender method I can't make sure what is the one being affected.
        • R Offline
          rui_mac
          Ok, found out what is wrong.
          The code inside the Output is being executed in multiple threads.
          So, one thread may be calculating the color of one object but the data I have in my struct is from another object being calculated by another thread.
          Is there any way to force a shader to be only calculate in a single thread?
          Or, is there any way to get a unique value from each object so that I can store a set of structures in the InitRender method, and detect which one is being rendered in the Output method and use the correct structure of data?
