    Scripted Rendering
    18 Posts 0 Posters 2.0k Views
      On 01/03/2004 at 20:36, xxxxxxxx wrote:
      Thanks Samir that did compile but now I get an application error when I use the code on 8.5 but not on 8.2.  I am not sure why though.
      Nate
        On 02/03/2004 at 03:17, xxxxxxxx wrote:
        Can you show the RenderDocument line you are now using?
        Samir
          On 02/03/2004 at 10:54, xxxxxxxx wrote:
          I don't have the code infront of me but believe the line looks as follows.   If its not I will post an update.
                  RenderDocument(m_dlg->m_doc,  m_dlg->m_rdata,
                                 ProgressFunction, m_dlg,
                                 m_dlg->m_bmp,
                                 uni_showerrors, this->Get());
          this is a Thread class
          Nate
            On 02/03/2004 at 11:30, xxxxxxxx wrote:
            you need to use the other RenderDocument function (seems you use the old one). It should look something like this:
            RenderDocument(doc,rdata,RenderProgress,NULL,bm,FALSE,Get())
              On 02/03/2004 at 12:28, xxxxxxxx wrote:
              What is the main difference between the way you use it and the way I use it?  This may be a stupid question but I don't see how they are different.
                                     m_dlg->m_bmp,
              m_dlg->m_doc = doc,  m_dlg->m_rdata = rdata, ProgressFunction = RenderProgress, NULL is m_dlg, m_dlg->m_bmp = bm, uni_showerrors = FALSE, this->Get = Get()
                On 02/03/2004 at 15:01, xxxxxxxx wrote:
                Well I just realized what is going on, I have a problem rendering when I use a different plugin I created and that is making the C4D crash for some reason.  The suggestion you gave me above does work.  Now I just have to figure out why the other object plugin crashes C4D when I render either the way above or to the picture viewer.  It also only happens when I place objects into the plugin object.  I may need to relook at the SDK for information about how to create an object plugin, maybe there is something in there about rendering plugin objects.  Thanks again for all your help you were very helpful!
                Nate
                  On 02/03/2004 at 18:13, xxxxxxxx wrote:
                  Sorry, I haven´t seen your m_dlg parameter you passed. My fault. It´s the same function of course then.
                  Hope you find the problem.
                    On 02/03/2004 at 20:59, xxxxxxxx wrote:
                    Thanks Mikael - this gives me a bit to chew on.
                      On 03/03/2004 at 16:11, xxxxxxxx wrote:
                      Ok - I have given Mikael's example a try. I did get the basic rendering to work but with two problems.
                      The first is that the changes I make to rdata seem to be ignored and it just goes ahead and uses the render settings from the scene such as framefrom, frametwo, filename, etc.
                      The second is that c4d crashes unless I comment out the line
                           ShowBitmap(pd->bmp);
                      in the progress function.
                      #include "c4d.h"
                      #include "c4d_symbols.h"
                      struct MyPrivateData
                           String* cam;
                           BaseBitmap* bmp;
                      void MyProgressHook(Real p, void* private_data)
                           StatusSetBar(p);
                           MyPrivateData* pd = static_cast<MyPrivateData*>(private_data);
                           StatusSetText("Rendering \"" + *pd->cam + "\"...");
                           //ShowBitmap(pd->bmp);
                      class RenderMenuTest : public CommandData
                                virtual Bool Execute(BaseDocument *doc);
                      Bool RenderMenuTest::Execute(BaseDocument *doc)
                           RenderData* rd = doc->GetActiveRenderData();
                           BaseContainer rdata = rd->GetData();
                           rdata.SetTime(RDATA_FRAMEFROM,     BaseTime(12, doc->GetFps()));
                           rdata.SetTime(RDATA_FRAMETO,     BaseTime(15, doc->GetFps()));
                           GePrint("Start frame: " + LongToString( rdata.GetTime( RDATA_FRAMEFROM ).GetFrame(30) ) );
                           GePrint("End frame: " + LongToString( rdata.GetTime( RDATA_FRAMETO ).GetFrame(30) ) );
                           const LONG N = 1;
                           for (LONG i = 1; i <= N; ++i)
                                AutoAlloc<BaseBitmap> bmp;
                                if (!bmp) break;
                                bmp->Init(rdata.GetLong(RDATA_XRES), rdata.GetLong(RDATA_YRES));
                                String cam = "cam" + LongToString(i);
                                BaseObject* cobj = doc->SearchObject(cam);
                                if (!cobj) break;
                                doc->GetRenderBaseDraw()->SetSceneCamera(cobj);
                                rdata.SetFilename(RDATA_PATH, doc->GetDocumentPath() + Filename(cam) + doc->GetDocumentName());
                           GePrint("Filename: " + rdata.GetFilename(RDATA_PATH).GetFileString());
                                MyPrivateData pd;
                                pd.cam = &cam;
                                pd.bmp = bmp;
                                if (RenderDocument(doc, rdata, MyProgressHook, &pd;, bmp, TRUE, NULL) != RAY_OK) {
                                     MessageDialog("Unable to write file...");
                                     break;
                           StatusClear();
                           MessageDialog("RENDER FINISHED!");
                      Bool RegisterRenderMenuTest(void)
                           // decide by name if the plugin shall be registered - just for user convenience
                           String name=GeLoadString(IDS_RENDERMENUTEST);
                           if (!name.Content()) return TRUE;
                           return RegisterCommandPlugin(1888956,name,0,"icon.tif","C++ SDK Rnder Menu Test Plugin",gNew RenderMenuTest);
                        On 06/03/2004 at 05:51, xxxxxxxx wrote:
                        The ShowBitmap line in the code above crashes c4d on a dual processor G5 but not on a single processor G4.
                        On the dual machine, it displays the rendering with one processor until the other processor would join in (with the second scan line) then it crashes.
                        Is there something that needs to be done to use ShowBitmap on a dual processor machine?
                          On 09/03/2004 at 05:04, xxxxxxxx wrote:
                          OK - I slogged my through it (is there any other way!)
                          Of the two problems I encountered, the first was that the camera FROMFRAME and TOFRAME attributes of the rdata BaseContainer seemed to have no effect. I went into the scene and changed Frame option in the "Output" section of the render dialog from "All Frames" to "Manual" and that seemed to do it. I guess that can also be set programatically with the RDATA_FRAMESEQUENCE container id.
                          The next problem of the crashing with the dual processor when it hit ShowBitmap was resolved as I went for the more sophisticated GeModalDialog subclass example that Mikael pointed to. Perhaps a separate thread was the necessary addition?
                          In any case it is all working now with the help of Mikael's ModalRenderer. Thanks Mikael!
                          There were a couple of things that had to be modified with the recent SDK. The original code is here:
                          [URL-REMOVED]
                          and the modifications are:
                          The GeUserArea can now only be gotten by:
                          gadgetarea = AddUserArea(PREVIEW_AREA_ID, 0, m_bmp->GetBw(), m_bmp->GetBh());
                          if (gadgetarea) AttachUserArea(ua,gadgetarea);
                          and AttachImage(PREVIEW_AREA_ID, m_bmp, 0);
                          no longer works so you have to sublass GeUserArea and define the draw command to draw the bitmap:
                          void RenderPreviewUserArea::Draw(LONG x1,LONG y1,LONG x2,LONG y2)
                               LONG w = bmp->GetBw();
                               LONG h = bmp->GetBh();
                               DrawBitmap(bmp,0,0,w,h,0,0,w,h,0);
                          Where bmp is a member variable of the RenderPreviewUserArea subclass.
                          Finally, in the GeModalDialog subclass, GetUserArea is no longer valid but the user area is now a member of the dialog subclass (was set by AttachUserArea in the dialog layout). So the UpdatePreview becomes:
                                    // Tell the preview to redraw itself
                                    void UpdatePreview() {
                                         // GeUserArea* ua = GetUserArea(PREVIEW_AREA_ID);
                                         ua.Redraw(TRUE);
                            On 09/03/2004 at 18:40, xxxxxxxx wrote:
                            Thanks for reporting back. I'm sure your results will be useful to future forum readers!
