    Get Point of an Object
    5 Posts 0 Posters 392 Views
      On 10/02/2004 at 04:10, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hi all
      I have one object
      BaseObject *ObjGrid = BaseObject::Alloc(Oplane);
      I wanna get the point of this particular location for this plane. So i convert it into polygon object:
         PolygonObject *ObjToPolygon;
         ObjToPolygon = (PolygonObject * ) ToPoly(ObjGrid);
      Now i wanna get the point of the particular location. Then I looked into the documentation so that i applied into my code:
          for(i=51; 2600; i++) {
         Vector *Prevpt;
           Prevpt = ObjToPolygon->GetPoint();
           if (Prevpt) {
             Prevpt[i - 51] ;
      Is what i am doing correct?
      Thanks and regards
        On 10/02/2004 at 04:37, xxxxxxxx wrote:
        1. Casting the Primitive Object doesn´t help here. It won´t be converted that way. You will need to convert the object with SendModelingCommand for example first and cast the resulting object.
        2. GetPoint should performance-wise be gotten before you jump into the loop (and of course you can check if the pointer is valid in front of the loop too). otherwise it´s correct that way.
          On 10/02/2004 at 15:31, xxxxxxxx wrote:
          Also, please note the typos in the "for(i=51; 2600; i++)". I suppose that was
              for(LONG i=51; i < 2600; i++)
          before the forum mangled it. Remember to wrap all code in code-tags, as described above the Message field, to avoid this.
            On 10/02/2004 at 18:09, xxxxxxxx wrote:
            Actually i have a piece of code in COFFEE
            for(i=0; i <=XNos; i++) {
            **      Vector *pt = BaseObject *Obj->GetPoint(i);**
            And I wanna translate it into C++, so i made like this:
            BaseObject *Obj = BaseObject::Alloc(Oplane);
            Vector *pt;
            **     pt = Obj->GetPoint();**
            **     if (pt) {
                  pt[i];  **
            Is that the same way to do it? Thanks for the reply
            Regards
              On 11/02/2004 at 17:50, xxxxxxxx wrote:
              No, BaseObject has no GetPoint() function. You have to get a "GetType()==Opoly" object first, for example by SendModelingCommand(), and then cast it to a PolygonObject.
