    Accessing HyperNurbs edge weights
    8 Posts 0 Posters 647 Views
      On 08/02/2004 at 11:16, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      How to access the HyperNurbs weighting for edges?
      Samir guessed earlier today in a very helpful post that it should be the same as accesing the weights of the points of the edge in question.
      However, this sound a bit weird as there is a huge difference in Cinema itself between points or edges set to 100% respectively.
      Or could/do I have to use sendmodeling to set that?
      Has anybody of you already manipulated edge HN weights?
      Thanks for any insight!
      Kabe
        On 10/02/2004 at 15:26, xxxxxxxx wrote:
        Edge weights are stored in the HNData::polyweight array.
          On 10/02/2004 at 23:02, xxxxxxxx wrote:
          Ooookay, naming seems a bit odd here IMO 😉
          Anyway - thanks a lot, that helped tremendously!
          So let me sum it up for anyone who might
          stumble later over this thread using search:
          Pointweights are stored in HN::pointweight
          Edgeweights are stored in HN::polyweight
          Polyweights are not stored as such, but as the combination of Point- and Edgeweights. This is also easy to proof inside Cinema. So if you would like to set the Hypernurbs weight of a polygon, you have to set the weights of all the attaching edges and points instead.
          Kabe
            On 20/04/2011 at 08:17, xxxxxxxx wrote:
            Howdy,
            Can someone show some example code of this?
            Adios,
            Cactus Dan
              On 28/04/2011 at 04:07, xxxxxxxx wrote:
              Simple example, printing the weights:
              Bool MenuTest::Execute(BaseDocument *doc)
                BaseObject *op = doc->GetActiveObject();
                if (!op) return FALSE;
                HNWeightTag *tag = (HNWeightTag* )op->GetTag(Tsds, 0);
                if (!tag) return FALSE;
                HNData hd;
                if (tag->GetTagData(&hd))
                    LONG pcnt = *hd.points;
                    LONG vcnt = *hd.polys;
                    LONG i=0;
                    for (i=0; i<pcnt; i++)
                        GePrint(LongToString(i)+" point weight: "+RealToString((*hd.pointweight)[i]));
                    for (i=0; i<vcnt; i++)
                        GePrint(LongToString(i)+" poly weight a: "+RealToString((*hd.polyweight)[i].a));
                        GePrint(LongToString(i)+" poly weight b: "+RealToString((*hd.polyweight)[i].b));
                        GePrint(LongToString(i)+" poly weight c: "+RealToString((*hd.polyweight)[i].c));
                        GePrint(LongToString(i)+" poly weight d: "+RealToString((*hd.polyweight)[i].d));
                On 28/04/2011 at 07:55, xxxxxxxx wrote:
                Howdy,
                Thanks Matthias. That fixed the crash. Can you explain the significance of the double "**" in the HNData structure?
                But, now I have another question: How would I assign values to the array?
                Adios,
                Cactus Dan
                  It's a pointer to an array. To access the array you have to dereference its array elements with the * oparator.
                  To assign a value do something like this:
                  (*hn.pointweight)[i] = myvalue
                    On 28/04/2011 at 08:16, xxxxxxxx wrote:
                    Howdy,
                    OK, thanks again, Matthias. 😉
                    Adios,
                    Cactus Dan
