    stop rendering
    9 Posts 0 Posters 956 Views
      On 01/02/2004 at 06:29, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      Hello
      It looked so easy....
      User starts plugin (compiled using 8.5 sdk)
      plugin copies the document and alters something
      plugin calls somehow RenderDocument(.....) to get a bitmap.
      O.k. that really does work. But now an additional preferable feature ..
      I would like to open a dialog with a simple button
          showing something like "Press Button to Stop Rendering".
          The problem is, that the dialog does not react while rendering
          and in MyThread::TestDBreak() a call to GetInputEvent(...)
          gets always FALSE, so now way to find a workaround.
      I've tried everything I could imagine. The only solution I found is
      to use another buttontext, for instance "Pull Plug to Stop Rendering".
      What is my mistake?
      thank you for any help ;o)
      dagmar
        On 01/02/2004 at 14:24, xxxxxxxx wrote:
        Hi Dagi,
        when overloading TestDBreak() you will need to check for a userbreak by calling TestBreak in your Render Thread.
          On 02/02/2004 at 04:09, xxxxxxxx wrote:
          Hi samir ;o)
          1. No. You can't do that. In fact it seems to be that TestBreak calls TestDBreak
          I've watched some really nice crashes caused by stackoverflow.
          2. Cinema must call the TestBreak - routine while rendering and Cinema does!
          The point is: Under that circumstances (meaning:Cinema executes
          RenderDocument(...)) the GetInputEvent(...) function is always FALSE;
          Anyway, it would be a workaround. It would be nicer to have that button.
          Any idea ????
          thx for answering
          dagmar
            On 02/02/2004 at 09:22, xxxxxxxx wrote:
            1. Sorry, but I can. I do it in my plugins exactly like this and I never encountered any problems nor a stack overflow, nor any crashes or whatever. It works perfectly. And yes, TestDBreak is called by TestBreak(), that´s why you need to use it!
            2. Cinema must do sh** ;o)
              On 02/02/2004 at 09:23, xxxxxxxx wrote:
              sh** means shine btw. 🙂
                On 03/02/2004 at 02:02, xxxxxxxx wrote:
                The problem is that TestDBreak() will be called from a non-GUI thread which means that it cannot safely access the GUI functions, like GetInputEvent(). Instead you have to let the dialog set a flag when the button is clicked, which the TestDBreak() function can check.
                  On 03/02/2004 at 07:54, xxxxxxxx wrote:
                  First - Thank you for answering ;o)
                  Fine. But I never watched a dialog function beeing executed
                  while RenderDocument(...) was running.
                  I must have misunderstood something important concerning the
                  RenderDocument() function.
                  Now I do it in the following way (coarse description, one of three or four
                  variants)
                  dialog->Open(ASYNCHRON,....)
                  MyThread.Start(...)
                  MyThread.Wait(...)
                  In MyThread::Main()
                          call RenderDocument(... ,this,...)
                  still getting crazy
                  Dagmar ;o)
                    On 09/02/2004 at 17:08, xxxxxxxx wrote:
                    If you have an asynchronous dialog then it shouldn't be locked up while the thread is executed. However, if MyThread.Wait() is called in the main thread then I think it will lock the GUI. Have you tried removing it?
                      On 06/09/2005 at 08:36, xxxxxxxx wrote:
                      May it not be a good idea to set a timer before calling to check every ??? ms if the caller is sending a message?
                      (It may be foolish! Just consider I'm not a programmer!)
