    SetSegments() is not working
    3 Posts 0 Posters 332 Views
      On 12/01/2004 at 09:02, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hi forum,
      I cannot get a COFFEE plugin to work that generates a spline with more than one segment. op->Message(MSG_SEGMENTS_CHANGED, vc); does not seem to work. Can anyone confirm this?
      Thanx in advance
      cheers mnu
        On 13/01/2004 at 06:11, xxxxxxxx wrote:
        Do you get a compilation error or a runtime error? If it's the former you could try to copy the message definition from the C++ API. If it's the latter, then please post a small snippet of source that shows how you create the spline.
          On 13/01/2004 at 06:34, xxxxxxxx wrote:
          Hi Mikael,
          I don't get any error. But the Spline simply does not have any segments after the call to op->Message. The SegmentCount is 0 although the segments array is formatted properly.
          cheers mnu
