    What plugin should it be?
    3 Posts 0 Posters 313 Views
      On 05/01/2004 at 06:16, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      I'm studying SDK and just want to creat a little plugin which will copy an omni light to five given points. First I think I should creat an object plugin which will creat/generate five "light" objects in this case, but the SDK said object plugin only generate polygon objects, then which plugin type should I chose in this case?
      Thanks.
        On 05/01/2004 at 16:40, xxxxxxxx wrote:
        You could use almost any type of plugin to do this, but the most obvious would be a Menu Plugin, which could have a possible GUI to allow different settings.
        You can indeed use an Object plugin to do what you want, I did this exactly with my PlaceOnPoints plugin (which you can get at http://www.spot4d.co.uk)
        I basically made a copy of the object, without converting it into a polygon. Which is why it will work with lights
          On 06/01/2004 at 03:35, xxxxxxxx wrote:
          Thanks, Geespot,
