    Setting Spline Points
    2 Posts 0 Posters 223 Views
      On 04/01/2004 at 03:46, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      i have Problem wie this Code, as Expression it works fine but in my Plugin only a empty Spline Object will be create but no points set, that makes me really wonder and  i dont find help with the forum search.
      thx a lot for help
      MfG Morph21
      MyDialog::CreateSpline()
      var count = 3;
      var doc = GetActiveDocument();
      //set spline
      var spline=doc->FindObject("ruler_spline");
      if (!spline && !instanceof(doc,SplineObject))
       var spline=new(SplineObject);
       spline->SetName("ruler_spline");
       doc->InsertObject(spline,NULL,NULL);
       spline->Message(MSG_UPDATE);
       return FALSE;
      //update new obj/point count
      var vc=new(VariableChanged); if(!vc) return FALSE;
      vc->Init(0,count);
      spline->Message(MSG_POINTS_CHANGED,vc);
      var points=new(array,count);
      points[0]=vector(0.0,0.0,0.0);
      points[1]=vector(100.0,0.0,0.0);
      points[2]=vector(0.0,100.0,0.0);
      spline->SetPoints(points);
      return spline;
        On 09/01/2004 at 13:39, xxxxxxxx wrote:
        A couple of things to check:
        1. What would spline->GetPoints() return, i.e. has it understood that the spline has three elements?
        2. Does calling spline->Message(MSG_UPDATE) help?
