    How to get the status of video post in python
    sdkpython
    4 Posts 3 Posters 1.2k Views 1 Watching
    • R Offline
      render_exe
      hello there!
      I want to get the status of video post, open or close, but I don't know the way, can you help me? Thank you!
        Hello @render_exe,
        Thank you for reaching out to us. The user you have been replying to was a spam-bot. I have removed the posting of the bot as well as your answer to it.
        About your Question
        The activation state of a video post node is expressed by the bit c4d.BIT_VPDISABLED. Find below an example for reading and writing the state of all video post nodes in the active render data.
        Result for running the script three times in a row on render settings which contain the 'Magic Bullet Looks' and 'Denoiser' video post effects.
        New state for video post 'Magic Bullet Looks' = False
        New state for video post 'Denoiser' = False
        New state for video post 'Magic Bullet Looks' = True
        New state for video post 'Denoiser' = True
        Code:
        """Demonstrates how to toggle the activation state of a video post node in a render data instance.
        Must be run as a Script Manger script.
            """Toggles the activation state of all video post nodes in the active render data.
            print ("-"*100)
            # Get the active render data and iterate over its video post nodes.
            renderData: c4d.documents.RenderData = doc.GetActiveRenderData()
            videoPost: c4d.documents.BaseVideoPost = renderData.GetFirstVideoPost()
            while videoPost:
                # If a video post is enabled or not is expressed as the bit #BIT_VPDISABLED. Remove the bit
                # when it is set, add it when it is not.
                state: bool = videoPost.GetBit(c4d.BIT_VPDISABLED)
                videoPost.DelBit(c4d.BIT_VPDISABLED) if state else videoPost.SetBit(c4d.BIT_VPDISABLED)
                print (f"New state for video post '{videoPost.GetName()}' = {not state}")
                videoPost = videoPost.GetNext()
        R 1 Reply Last reply Reply Quote 0
        • R Offline
          render_exe
          This post is deleted!
          • R Offline
            render_exe @ferdinand
            @ferdinand Thank you, the code runs well. └(^o^)┘
