    Matrice accessing members of...
    6 Posts 0 Posters 514 Views
      On 02/01/2004 at 17:22, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hello All,
      I hope that you all had a safe and happy New Years..
      On to my question...
      I am using NAMM's bone spline COFFEE tag, and was wondering if there were a way to just have the spline set the bone chains position by just outputting the heading and pitch info and to leave the banking open so that I may manipulate it with an up vector node I found..
      Currently I have a an identical system that it's parts are getting their orientation (H and P and using this up vector node to control the banking. It is a bit slow and I am trying to optimize it so that I only need to use one bone chain system..
      currently the coffe code does a
      [rot=VectorToHPB(pos1-pos);
                op1->SetRotation(rot);
                op1=op1->GetDown();]
      and I was wondering of I could deconstruct the
      SetRotation(rot) so that I may acces it's members..
      Little help?
      -Danny
        On 03/01/2004 at 04:58, xxxxxxxx wrote:
        you can easily use SetRotation(vector(rot.x,rot.y,rot.z)) and replace (or do whatever you like :), one of the vector components
        hth
          On 04/01/2004 at 16:39, xxxxxxxx wrote:
          Is there any way of leaving one of thevectors blank so that I can access that variable with a separate operation? I have an up vector node that interpolates between 2 up vector targets. I want to use it in tandem with the coffe script from NAAM..
          Thanks fotr the reply
          -Danny
            On 04/01/2004 at 18:13, xxxxxxxx wrote:
            what do you exactly mean? you can replace each variable whenever you want.
            var new_comp = YourOperation(upvector);
            and then insert your vector (or components of it) wherever you want.
            Or do you mean something else? Show some code. It´s hard to guess what you want to do.
              On 05/01/2004 at 03:01, xxxxxxxx wrote:
              I think what you're looking for is:
                  var oldrot = op->GetRotation();
                  op->SetRotation(vector(rot.x, rot.y, oldrot.z));
                On 05/01/2004 at 04:33, xxxxxxxx wrote:
                hö? I thought that´s already what I have answered in my first reply. Sometimes I don´t get smarter out of it no matter how many answers I give 🙂
