    Cutpoint of a sphere with a spline
    4 Posts 0 Posters 544 Views
      On 16/12/2003 at 02:20, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      How i can calculate this in coffee?
      Cut of a sphere with a line is not a problem. But a sphere with C4D spline object - i dont know.
        On 24/12/2003 at 02:55, xxxxxxxx wrote:
        You can get a point along the spline as well as the tangent. Then you can just search for the cutpoint numerically. (See SplineObject.)
          On 27/10/2004 at 03:09, xxxxxxxx wrote:
          is there Xpress/COFFEE combination for this? Mikael your method doesn't give exact point but only an estimation.
            On 27/10/2004 at 05:52, xxxxxxxx wrote:
            I doubt there is an analytical solution to your problem, you'll have to go with some kind of numerical estimation anyway. The best is probably to use the Line Segments generated from the Spline anyway, because otherwise you won't be able to include any effects that come from deformation. Intersection of Line Segments with Spheres should be pretty simple again.
            Hope that helps
            Timm
