    Need help getting an old script to work in C4D
    8 Posts 3 Posters 941 Views 1 Watching
    • B Offline
      bstone
      Hey all, I found this post from 11+ years ago by a user named
      "bandini" that has a bit of code to bake animations. I am trying to update the code so that it works with the current version of C4D. Any help would be appreciated! Thanks!
      https://forums.cgsociety.org/t/holy-grail-bake-mograph-objects-to-keyframes/1296975/10
      This is what I've converted so far but I am receiving an error on line 11 that says:
      in <module>
      while current_frame <= user_end_time:
      NameError: name 'StopAllThreads' is not defined
      Here is the "updated" script that is giving me the error
      user_start_time = 0
      user_end_time = 90
      fps = doc.GetFps()
      bake_start_time = doc.GetTime()  # needed to initialize a BaseTime object
      doc.SetTime(bake_start_time)  # set the time slider to the user's start time
      current_frame = doc.GetTime().GetFrame(fps)
          StopAllThreads()
          CallCommand(12410)  # record
          user_start_time += 1
          doc.SetFrame(user_start_time)  # Set the current frame of the time slider
          redraw = DrawViews(DA_STATICBREAK)
          EventAdd(EVENT_ANIMATE)
          if redraw:
      • B Offline
        bentraje
        Maybe add c4d? Like c4d.StopAllThreads() ?
        • B Offline
          bstone
          When I try that, I get an error that says "NameError: name 'c4d' is not defined"
          • B Offline
            bentraje
            because your have to add
            at the start of every c4d script.
            • B Offline
              bstone
              Thank you, by adding the "import c4d" at the beginning of the script and "c4d." in front of the lines below, that solved the issues with the
              StopAllThreads()
              However, now line 16 says:
              line 16, in <module>
              c4d.SetFrame(user_start_time) # Set the current frame of the time slider
              AttributeError: module 'c4d' has no attribute 'SetFrame'
              • B Offline
                bstone
                Here are the scripts (original and modified), as well as the c4d file if that is helpful
                https://www.dropbox.com/sh/vwnkj9x08b9dg0k/AACWhSoQV4rYo3ECMkNIZ2Kda?dl=0
                • B Offline
                  bentraje
                  Hi @bstone
                  Thanks for providing the modified script.
                  API changed throughout the release. One of those probably is the SetFrame (i.e no longer exist).
                  Here's what I have.
                  user_start_time = 0
                  user_end_time = 90
                  fps = doc.GetFps()
                      c4d.CallCommand(12410)  # record
                      #doc.SetFrame(user_start_time)  # Set the current frame of the time slider
                      pTime = c4d.BaseTime(user_start_time,fps)
                      doc.SetTime(pTime)
                      redraw = c4d.DrawViews(c4d.DA_STATICBREAK)
                      c4d.EventAdd(c4d.EVENT_ANIMATE)
                      if redraw:
                    ferdinand @bentraje
                    Hello @bstone,
                    Thank you for reaching out to us and welcome to the Cinema 4D community. And thank you @bentraje for answering the question. We do not have to add anything here, @bentraje already pointed out all the important bits 🙂
