    Add Additional Script Path?
    r25python
    3 Posts 2 Posters 613 Views 1 Watching
    • B Offline
      bentraje
      The plug-ins now have an add folder option in the preference setting.
      Is there a script equivalent for that?
      Currently, the script should be located either somewhere in the user documents or in the installation directory, both of which are inconvenient to store. I'd rather point it to a dropbox folder where I store all my scripts and can easily refer.
      Is this possible?
        Hi @bentraje, for the moment there is only the environment variable C4D_SCRIPTS_DIR that you can define. However this can't be set for a specific Cinema 4D version and this will be global. You can also add multiple path by separating them with a ;.
        B 1 Reply Last reply Reply Quote 1
        • B Offline
          bentraje @m_adam
          @m_adam
          Thanks for the response. Modifying the environment varialbles works for my use case.
          Closing the thread now.
