    Particles
    4 Posts 0 Posters 459 Views
      On 01/12/2003 at 14:31, xxxxxxxx wrote:
      Cinema 4D Version:   8.206
      Hi
      I want to be able to get each particle position of the particles that are emitting from an emitter. After many searches on this forum and the archieved forum I believe I have to use a ParticleTag. But I dont know *how* to use the ParticleTag. I thought it would mean just inheriting the ParticleTag class
          class MyParticle : public ParticleTag
      but that gives me an error
      'MyParticle' : no appropriate default constructor available
      What am i doing wrong?
        On 05/12/2003 at 08:47, xxxxxxxx wrote:
        Hi Geespot,
        I currently don't do C++ but I remember the procedure in COFFEE. The particle tag is an invisible tag every standard C4D particle emitter has. It's its first tag I think. To access it you have to search for the first active tag of the emitter. If I remember correctly.
        cheers mnu
          On 06/12/2003 at 01:00, xxxxxxxx wrote:
          Its fairly simple, quick snap of some code:
              if (op->GetType()==Oparticle)
              ParticleTag *ptag=(ParticleTag* )op->GetTag(Tparticle);
              if (!ptag) return;
              LONG pcnt=op->GetParticleCount();
              for (LONG i=0;i<pcnt;i++)
              Particle *pt=op->GetParticle(ptag,i);
              if ((pt->bits&(PARTICLE_VISIBLE|PARTICLE_ALIVE))!=(PARTICLE_VISIBLE|PARTICLE_ALIVE)) continue;
          the key is to get the tag (which as mnu said is hidden), use GetTag() to do this. If found, then use the functions of the tag (ParticleTag) to get the particles.
            On 06/12/2003 at 06:20, xxxxxxxx wrote:
            Thank you to both. I was going about it the wrong way, which is why I was confused.
