    TextDialog() not working?
    7 Posts 0 Posters 749 Views
      On 19/11/2003 at 08:40, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:    Mac  ;
      For some reason I can't get the TextDialog() function to work. The following code compiles and runs without generating any errors, and when I attach it to an object, it prints out to the console no problem every time the object moves. But I'm not seeing any dialog boxes.
      Is this a bug, or am I doing something wrong?
      main(doc,op)
      var result = TextDialog("Hello World",DLG_OKCANCEL DLG_ICONEXCLAMATION);
      println("Hello Console");
        On 19/11/2003 at 09:11, xxxxxxxx wrote:
        dialog boxes cannot be called from within an expression.
        Samir
          On 19/11/2003 at 09:25, xxxxxxxx wrote:
          O_o
          You've got me confused now! The documentation[URL-REMOVED] didn't mention anything about not calling it from inside an expression.
          When is it OK to call TextDialog()?
            On 20/11/2003 at 05:19, xxxxxxxx wrote:
            From within a "real" plugin you can call TextDialog without any problems. The documentation isn´t always complete...
              On 21/11/2003 at 08:05, xxxxxxxx wrote:
              Making calls that completely block the interface from a thread is never a good idea 🙂
                On 21/11/2003 at 08:33, xxxxxxxx wrote:
                Sure it is. when a critical situation occurs this is the perfect way to let the user choose whether to continue or not, instead of letting him accidently choose the wrong one (which probably rather happens if he can keep on working, is annoyed by a window and just clicks it away...that´s at least what the experience tells us).
                  On 21/11/2003 at 10:45, xxxxxxxx wrote:
                  I agree with Samir!
