    Current state to object
    7 Posts 0 Posters 645 Views
      On 19/11/2003 at 06:05, xxxxxxxx wrote:
      Cinema 4D Version:   7.3
      Platform:   Windows  ; Mac  ;
      I can't get the current state to object modeling command to work. It returns 1 after execution, so all is supposedly well, but there's no effect in the doc! Here's the code:
      oMenuPlugin::Execute(doc)
      var op=GetActiveObject(doc); if (!op) return FALSE;
      var bc=new(BaseContainer);
      SetMousePointer(MOUSE_BUSY);
      doc->StartUndo();
      doc->AddUndo(UNDO_OBJECT_REC,op);
      var test = SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT,NULL,op,bc,MODIFY_ALL);
      println(test);
      doc->EndUndo();
      SetMousePointer(MOUSE_NORMAL);
      GeEventAdd(DOCUMENT_CHANGED);
        On 19/11/2003 at 09:13, xxxxxxxx wrote:
        you have to pass the document pointer. SendModelingCommand will then create the object in this document afai can remember (long time I used it in COFFEE)..
          On 19/11/2003 at 10:58, xxxxxxxx wrote:
          Thank you Samir, that fixed it!
            On 19/08/2006 at 09:37, xxxxxxxx wrote:
            I have the same Problem !
            I try all I think what you may mean with pass the document.
            It's sounds like make a new(BaseDocument) but I can't get a working code 😞
            What are the missed code to go working ?
              On 19/08/2006 at 11:14, xxxxxxxx wrote:
              Hi Jack , i think it should read:
              SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT,doc,op,bc,MODIFY_ALL);
              Greetings , Frank.
                On 19/08/2006 at 11:57, xxxxxxxx wrote:
                Thanks for answer, but his I had try before and don't work.
                The Problem Stay.
                At first Time the Deformer "baked" in a new object.
                But after set Time one frame again, nor the new deformed object baked.
                Only the deform of start is bake again and again in new Objekt.
                    while(time->IsLT(ends))
                    doc->SetTime(time);
                    var bc = new(BaseContainer);
                    var ddoc = new(BaseDocument);
                    var savename = op->GetName();
                      op->SetName(tmp_Name+tostring(cc));
                      SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, doc, op->GetUp(), bc, MODIFY_ALL);
                    var Deformer_Hierarchie_copy = doc->GetActiveObject();
                      op->SetName(savename);
                    var deformed_op = doc->FindObject(tmp_Name+tostring(cc));
                    var i,pointcount = op->GetPointCount();
                    var points = new(array, pointcount);
                    var key = new(PLAKey);
                      key->SetTime(time);
                    var pt  = new(PointTag);
                    for (i=0; i<pointcount; i++){ points[i] = deformed_op->GetPoint(i);}
                      Deformer_Hierarchie_copy->Remove();
                    var vc = new(VariableChanged);
                      vc->Init(0, pointcount);
                      pt->Message(MSG_POINTS_CHANGED,vc);
                      pt->SetData(points);
                      key->SetPointTag(pt);
                      seq->InsertKey(key);
                      cop->Message(MSG_UPDATE);
                      time->Add(OneFrame);
                      cc++;
                  On 20/08/2006 at 08:46, xxxxxxxx wrote:
                  Hi jack , i'm not sure if i understand you correctly but should'nt it be
                  bc->SetData(MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, TRUE);
                  HTH , frank.
