    How to activate the recent Saved Document
    pythonr25
    3 Posts 2 Posters 613 Views 2 Watching
      mogh
      Dear Developers,
      I have a python script which saves the unsaved (untiteled) active document to a *_imported.c4d file which works fine, but Cinema still has the original "Untiteled" Filename active how can I activate the successfully saved file in Cinema 4D and discard the "untiteled"
      thanks in advance.
      here is my save method:
          def savedoc(self, doc):
              c4d.StatusSetText ('Saving Document.')
              path = self.folderpath
              if doc.GetDocumentPath():
                  path = doc.GetDocumentPath()
              name = doc.GetDocumentName()
              # an unsaved doc has no extension we have to check
              if name[-4:] == ".c4d":
                  newname = name # the user has his own document we dont change the name
                  newname = name + "_imported.c4d" # the user has no document we give a little context
                  # c4d does not update to _imported.c4d doc.
                  #doc.SetName(newname)
                  #c4d.documents.SetActiveDocument(doc)
              filename = os.path.join(path, newname)
              print ("Saving file to: ",  filename)
              c4d.documents.SaveDocument( doc, filename,                                     c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST | c4d.SAVEDOCUMENTFLAGS_DIALOGSALLOWED, format=c4d.FORMAT_C4DEXPORT)
      fwilleke80F 1 Reply Last reply Reply Quote 0
      • fwilleke80F Offline
        fwilleke80 @mogh
        @mogh Did you try doc.SetDocumentName(newname)?
        www.frankwilleke.de
          mogh
          No stupid me,
          overlocked this ... thanks for the hint Frank.
