    Set "Strength" on Constraint tag via Python Xpresso Node?
    2 Posts 1 Posters 612 Views
    • J Offline
      joel-mic
      Hey Folks,
      I am very uninitiated in Python, but I assume this is a very easy setup.
      I have an Object in a hierarchy with a Constraint tag.
      I want a Python Xpresso node where I can pipe in an Object link and a float value. I need the code to then set the "Strength" (Constraint Tag, Aim tab) to the Float value I plug in.
      Can anyone spell out for me how to set this up? Thanks!
      • J Offline
        joel-mic
        Ok, nevermind... I got something working about 3 minutes after posting this question. I'll paste below what worked for my needs. Maybe this will help someone else, or maybe you all have a more direct method to achieve this.
            #inputs to the Xpresso Node are Link (named "LayerLink") and Float (named "FieldtInfluence")
            myObject = LayerLink
            myTag = myObject.GetTag(1019364)
            myTag.SetParameter(c4d.ID_CA_CONSTRAINT_TAG_AIM_TWEIGHT, FieldInfluence, c4d.DESCFLAGS_SET_0)
