    Execute MenuPlugin after selecting points
    5 Posts 0 Posters 591 Views
      On 08/11/2003 at 17:51, xxxxxxxx wrote:
      Cinema 4D Version:   8.207
      Is it possible to execute a MenuPlugin after selecting points in polygon object?
      It is easy if the plugin is Tag, however I could not get how can I do this with the MenuPlugin.
      Please help.
        On 11/11/2003 at 15:50, xxxxxxxx wrote:
        No, there are no such hooks in a MenuPlugin and no specific messages for this are sent. (Perhaps it would be possible to do what you want by using an invisible tag?)
          On 11/11/2003 at 19:03, xxxxxxxx wrote:
          Thanks Mikael.
          I finally make the tool by XPresso and COFFEE node. It is very irregular use, but still work fine as my first idea (automatic tool execute afetr selecting elements).
          You can see the result in my web site.
          http://www.c4djug.com/expression/ex.html#8
            Hey,
            Thoshio, now that is clever! 🙂 Like it a lot.
            Best
            Samir
              On 12/11/2003 at 12:10, xxxxxxxx wrote:
              > Hey,
              > Best
              > Samir
              Tnaks Samir.
              It is what the "Metasequoia (The most used modering Application in Japan)" does. I think it is out of regular MacOS interface or C4D interface, but has much advantage in tough modering jobs.
              MAXON says everytime "CINEMA 4D can do same thing", however point is not in result, but in time and operation steps which is necessary to get the result.
