CKey left/right Python methods
Could someone please enlighten me: what exactly do these Python CKey left/right methods do? The documentation is somewhat... vague
(the text below is taken directly from Maxon's Python API documentation pages).CKey.GetTimeLeft(self) : "Get the left time of this key"
CKey.GetTimeRight(self) : "Get the left time of this key"
CKey.GetValueLeft(self) : "Get the value of this key"
CKey.GetValueRight(self) : "Get the right of this key"CKey.SetValueLeft(self, seq, v) : "Set the left value of this key"
CKey.SetValueRight(self, seq, v) : "Set the right value of this key"
CKey.SetTimeLeft(self, seq, t) : "Set the left time of this key"
CKey.SetTimeRight(self, seq, t) : "Set the right time of this key"(as I've suggested before: Maxon should really REALLY put more resources in the API documentation quality)
These are times and values of the right and left tangents of the keys. See the C++ documentation:
https://developers.maxon.net/docs/cpp/2023_2/page_manual_ckey.html#page_manual_ckey_edit_tangentsYeah, it would be fairly helpful if the word "tangent" would be mentioned in the Python docs...
Thank you, Cairyn. When you document method "SplurgeMiddlePhalange()" with "this method splurges your middle phalange", you're not really helping anyone...
A followup question: is there a way to get the time and/or value of previous/next keyframe of a CKey (on the same track)? I was hoping these mysterious left/right methods would do that, but apparently not.
@heilei Yeah, there is quite a bit of that "self-evidently documented" stuff in the C4D docs. But I'm not working for Maxon, I'm just the nagging guy
CKeyis derived fromGeListNodewhich has theGetNext()/GetPrev()methods. So theoretically it may be possible to walk through the key list of a track by using these. But actually I see only examples where the keys are iterated byGetKey()on the curve.When I look at the
GetNext()keys on a normal curve, it seems to be correct:curve = track.GetCurve() if curve is None: continue for key_id in range(curve.GetKeyCount()): key = curve.GetKey(key_id) print ("This:", key, key.GetTime().GetFrame(doc.GetFps()), key.GetValue()) if key.GetNext() != None: print ("Next:", key.GetNext(), key.GetNext().GetTime().GetFrame(doc.GetFps()), key.GetNext().GetValue())I haven't done all that much with keys though, so maybe there is a reason not to do it by the
GeListNodefunctions. I will leave the answer to that question to the Maxon crew. -
CTrack documentation talks about โindexโ a lot, when referring to keys, but I havenโt yet found any definite specification for it. Are the keys indexed in what order? Time? Order of insert? Random? Does the index start from 0 or 1?
I guess this means what
curve.GetKey(key_id)is for. Range starts at 0 and ends withcurve.GetKeyCount()-1(inclusive).I tried inserting a key through the GUI, and it appears in the correct (time) sequence, no matter whether I use the curve's key index or the
GetNextmethod. -
Ok, thanks for the clarification.
