    claude bonet
    6 Posts 0 Posters 734 Views
      On 30/09/2003 at 09:49, xxxxxxxx wrote:
      Cinema 4D Version:   8.207
      Is there a way to access CB weight tags via coffee? Just checking with a coffee node, seems they're from the class baseTAG. Not very helpful.
      naam
        On 01/10/2003 at 00:34, xxxxxxxx wrote:
        they are just vertex maps, so should be possible?
          On 01/10/2003 at 00:46, xxxxxxxx wrote:
          Well, they are vmap tags with a direct link to the bones. But I need to know how to access them via coffee. I managed to figure out that their basecontainer has the bonelink at Id 1000, but didn't manage to get to the actual vertex map information yet. I mean, a vertex map tag is a variable tag, while the secret CB tag is a basetag. So GetData doesn't work.
          naam
            On 01/10/2003 at 03:43, xxxxxxxx wrote:
            they are variable tags (basically just vertex tags!), don't know how you do it in coffee though, in c++ they are treated the same, as for the container ids, look at the res files in the mocca folder.
              On 01/10/2003 at 03:47, xxxxxxxx wrote:
              hmmm, must be coffee running in the emulation layer then. When I do a getclass call on the tags, I get class BaseTag, not VariableTag, and the GetData method doesn't work on them (function not found).
              anyone having ideas?
                On 02/10/2003 at 05:36, xxxxxxxx wrote:
                No, I think it's impossible then.
