    Setting up global plugin structs
    3 Posts 2 Posters 428 Views 1 Watching
    • WickedPW Offline
      WickedP
      Hi folks,
      I've had a persistent issue with setting up some plugins with global structs. I'm sure I've read about this previously, maybe something to do with symbols not being loaded before PluginStart() is called? I forget the details...
      Anyhow, is there a 'correct' way to setup a global struct for my plugin, that has BaseContainers, Strings etc in it? Take this for example, if I do this:
      // global struct
      struct MyStruct
          BaseContainer bc;
      }mystruct;
      the plugin fails to start and I get a crash file with nothing in it. If I do this:
      // global struct
      struct MyStruct
          std::vector< BaseContainer > bc;
      }mystruct;
      then the plugin loads. Obviously I have to take care of the array, but that aside. Is there a way of having a global struct load with Cinema objects, without cheating it like this? Or - is there a better cheat...
      WP.
      wickedp.com
        after you struct declaration, you are adding mystruct witch will create a variable of the type of your structure.
        It try to allocate a BaseContainer that is unknown.
        If you add that to a Vector, as the vector is empty, it doesn't try to allocate a BaseContainer.
        I'm not sure why you need a global structure, but I would create a pointer and in pluginstart and pluginend take care of assign memory and free it.
        // global struct
        struct MyStruct
            BaseContainer bc;
        MyStruct *g_mystruct = nullptr;
        You can have a look at Entity Creation in our documentation.
        WickedPW 1 Reply Last reply Reply Quote 0
        • WickedPW Offline
          WickedP @Manuel
          Hi Manuel,
          what you say rings a bell. I was sure it was because the vector hadn't allocated anything yet.
          Global possibly wasn't the best way admittedly, it just started like that for convenience. But it ended up being a bit complex, there's a lot of things accessing it, so I didn't want to change it (for now).
          @m_magalhaes said in Setting up global plugin structs:
          hadn't thought of that. Seems to work - I'll go with that! Thanks 👍
          WP.
          wickedp.com
