    How toAdd Points to Polygon
    3 Posts 0 Posters 476 Views
      On 11/09/2003 at 06:43, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Hi
      I thought this would be simple to do, but after 2 hours at trying and searching, I give up.
      All I want to do is simply add a point to a polygon object. Basically the same as using the AddPoints command.
      Could someone please explain to me how this is done
        On 15/09/2003 at 22:44, xxxxxxxx wrote:
        do somthing like this
            point_cnt=ToPoint(op)->GetPointCount();
            poly_count=ToPoly(op)->GetPolygonCount() :
            ToPoly(op)->ResizeObject( poly_count, point_cnt+1 );
            now your object has 1 more point than it had before.
            you have to get the pointer to  points **after** you resized/ same for polys if they changed.
          On 20/09/2003 at 16:36, xxxxxxxx wrote:
          Thank you, that was exactly what i was after
